Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Glass Material |
| Print at Sep 10, 2026, 8:08:31 AM | |
| Posted by Rahulp82 at Jun 23, 2014, 1:25:03 PM |
Glass Material I want to make my own Glass Window. How ever I managed to make it in sweet home 3D itself. But I cannot make glass material. Do anybody please help to make glass or How can I make glass texture to the object with 100% transparency. Thanks ![]() |
| Posted by hansmex at Jun 23, 2014, 1:27:52 PM |
Re: Glass Material Check out these files .... H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jun 23, 2014, 1:32:20 PM |
Re: Glass Material If you make it 100% transparent, you won't see it at all ![]() I you really want to make it with Sweet Home 3D without editing OBJ or MTL files, you can use an imported half transparent texture. Editing the MTL file with a text editor and changing the d value of the material you want to be transparent (0.0 for fully transparent and 1.0 for fully opaque) is probably easier though, and may lead to more consistent results with the photo creation tool. If you're not trying to modify an existing 3D model, using the transparent boxes Hans pointed to will be very helpful too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stiiknafuulia at May 6, 2021, 3:56:39 PM |
Re: Glass Material Thank You, hansmex and Puybaret, now I succeeded in making both square (box) and round (cylinder) table tops of glass material with 0,75 transparency. |
Current timezone is GMT Sep 10, 2026, 8:08:31 AM |
