Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sw 3D in Linux |
| Print at Sep 13, 2026, 11:45:43 PM |
| Posted by pmralbuquerque at Jun 15, 2014, 1:00:33 PM |
Sw 3D in LinuxHi, I'm trying to install v4.4 in Linux Lite. After extracting the files, I find a file named 'SweetHome3d' with a command line symbol. If I read well the instructions on the site page, executing this file should install SW3D. But nothing happens. What am I doing wrong, please? I must say that I am an absolutely new user of Linux and know very very very little about this OS. The downloaded version is Linux 64 bits.Thank you. |
| Posted by hansmex at Jun 15, 2014, 1:51:21 PM |
Re: Sw 3D in Linux You don't have to install SH3D. 1 - Unzip the file you downloaded. 2 - Right-click the SH-script (881 bytes) 3 - Choose Properties 4 - Under Permissions check the box before Allow execution as program 5 - Under Open with verify that the program uses Oracle Java 7 Runtime 6 - If necessary, uninstall all Java versions and install Oracle Java 7. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jun 15, 2014, 2:08:20 PM |
Re: Sw 3D in Linux You don't need to install Oracle Java with the installer version proposed on sweethome3d.com and SourceForge.net. Just double-click on the SweetHome3D file and it will run the program itself since there's no real installer program. When you double-click on SweetHome3D, the system might prompt you to Run the program in a terminal or not. If it fails, run it in a terminal, and report here the issue that may appear in the terminal. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pmralbuquerque at Jun 16, 2014, 7:44:46 PM |
Re: Sw 3D in Linux Hi, thank you for your answers Hansmex and Emmanuel, but I still haven't got it .Let me try to explain better:
Then ... nothing happens .Maybe there is something else I should do? Thank you again. Regards. |
| Posted by Yuri_fromBY at Jun 16, 2014, 8:17:01 PM |
Re: Sw 3D in Linux Hi, I have the same problem, but with the x86 version in Ubuntu 14.04. " minsk@minsk-G41MT-D3V:~$ java -version Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar java version "1.7.0_60" Java(TM) SE Runtime Environment (build 1.7.0_60-b19) Java HotSpot(TM) 64-Bit Server VM (build 24.60-b09, mixed mode) minsk@minsk-G41MT-D3V:~$ javac -version Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar javac 1.7.0_60 " |
| Posted by Puybaret at Jun 16, 2014, 8:18:12 PM |
Re: Sw 3D in Linux That sounds correct. Try to run it in a Terminal window to see if some errors appear: - Open a Terminal - Drag and drop the SweetHome3D icon in the Terminal to get its path easily - Type <Enter> to run it - Report here what the Terminal says. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Yuri_fromBY at Jun 16, 2014, 8:41:17 PM |
Re: Sw 3D in Linux minsk@minsk-G41MT-D3V:~$ '/home/minsk/SweetHome3D-4.4/SweetHome3D' Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/minsk/SweetHome3D-4.4/jre1.6.0_45/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.load0(Unknown Source) at java.lang.System.load(Unknown Source) at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.loadLibrary0(Unknown Source) at java.lang.System.loadLibrary(Unknown Source) at sun.security.action.LoadLibraryAction.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.java2d.Disposer.<clinit>(Unknown Source) at javax.imageio.stream.FileCacheImageInputStream.<init>(Unknown Source) at com.sun.imageio.spi.InputStreamImageInputStreamSpi.createInputStreamInstance(Unknown Source) at javax.imageio.ImageIO.createImageInputStream(Unknown Source) at javax.imageio.ImageIO.read(Unknown Source) at com.eteks.sweethome3d.swing.SwingTools.showSplashScreenWindow(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) minsk@minsk-G41MT-D3V:~$ |
| Posted by Puybaret at Jun 17, 2014, 10:42:21 AM |
Re: Sw 3D in Linux Maybe the answer to a similar problem will help you... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Yuri_fromBY at Jun 17, 2014, 11:36:04 AM |
Re: Sw 3D in Linux Emmanuel, thank you a lot! "sudo apt-get install libxtst6:i386" - it helped. |
| Posted by amyelizabeth at Jun 19, 2014, 2:43:54 AM |
Re: Sw 3D in LinuxHowdy, Important info: OS: Linux Trusty Tahr 14.04 Arch: 32bit So I installed SW3D, or tried to. I extracted the files and when I click the app to run all the program does is open Gedit. I allowed the executing file as program, but it still won't work. I did move the file to a different location, Home file. Yet, the app still only opens in Gedit. I have Java 6 and 7, I installed IcedTea. My OS has the latest version on libXtst. I dragged and dropped the app into Terminal and it opens with the Terminal stating: Java 3D: implicit antialiasing enabled However, I would like to run the app without having to route through Terminal. What am I doing wrong? ![]() Any help is greatly appreciated! Thank you |
Current timezone is GMT Sep 13, 2026, 11:45:43 PM |
