Print at Sep 14, 2026, 2:16:06 AM
Posts: 112   Pages: 12   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Posted by Daniels118 at May 11, 2022, 9:59:51 AM
Re: Pan tool in 3D and 2D view?
I'm not sure what causes the problem, I have even tried to swap left and right mouse buttons in Windows settings, but it stil works as expected for me.
Anyway I have modified the code to handle both buttons, please try the attached version and let me know.
Pan3dView-3.2.2.sh3p
Posted by Daniels118 at Jul 8, 2022, 1:30:30 PM
Version 3.3 released!
Changelog:
  • Added SPACE+left mouse button for panning as in plan view
  • Added Czech translation
  • Minor bug fix
Download from sourceforge or using the Plugin Manager.
Known bugs:
The "hide obstacles" feature is broken in Sweet Home 3D 7 beta. I'll try to fix it once SH3D 7 gets out the beta stage.
Posted by Puybaret at Jul 9, 2022, 8:46:32 PM
Is there something I should have not changed in the program? Maybe it can be updated easily to avoid you to change your plug-in and manage different versions of Sweet Home 3D…
Posted by Daniels118 at Jul 12, 2022, 10:55:25 AM
The problem is caused by the addition of the modelFlags parameter to the HomePieceOfFurniture3D.setVisible method, since it's a private method I did expect my code would have break soon or later. Handling both versions should be quite easy anyway.
Posted by Puybaret at Jul 12, 2022, 1:36:24 PM
I could overload setVisible to keep the old signature too, but as it's a private method, the old version of the method will lead to warnings in Eclipse because it will be unused.
Thanks for accepting to fix it on your side smile
Posted by Daniels118 at Jul 13, 2022, 10:40:31 AM
Version 3.4
Changelog:
  • Fixed "hide obstacle" feature not working in SH3D 7
Posted by Daniels118 at Sep 14, 2022, 6:27:03 PM
Version 3.5
  • Fixed the camera jumping bug
  • Fixed Dutch translation
Download the new version from SourceForge or using the Plugin Manager.
Posted by Daniels118 at Nov 25, 2022, 8:39:59 PM
Version 3.6
  • Added the ability to change the 2D/3D panes layout
    Use View 3D -> Pan 3D view settings and check Use widescreen layout.
Don't forget that you can always use CTRL+SPACE to cycle the layout between full plan, full 3D and split.
Download from Sourceforge or using the Plugin Manager.
Posted by hansmex at Nov 25, 2022, 9:14:20 PM
Nice, nice, nice!!!
Posted by Daniels118 at Dec 19, 2022, 11:17:13 PM
Version 3.7
New features:
  • Added the ability to change the 3D view to parallel projection using CTRL+J (this also enable outlines to improve the aspect)
  • Added the ability to align the camera to the selected furniture or wall using CTRL+K (can be pressed multiple times to align to different sides)
View full size
These new features together with the 3D dimension lines plugin will enable SweetHome3D to produce pseudo-technical drawings in the 3rd dimension. I will publish a video tutorial in the next weeks.
You can download the new version from SourceForge or using the Plugin Manager.
