Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: obj Transparency? |
| Print at Sep 30, 2026, 7:49:07 PM |
| Posted by pencilart at May 21, 2014, 9:34:00 PM |
obj Transparency?I need to track down if this problem is in SweetHome 3D or AOI 3.0: 1) In AOI (3.0) make a cylinder (or any other shape) 2) assign a transparent texture to it (all else is default) 3) export it as .obj 4) import it into SweetHome 3D Notice the transparency is NOT transparent. This all used to work for me in the past with no problems with transparency exports. I have contacted the coders of Art Of Illusion too to see if the problem is there, but I just want to track this down. P.S. I am on Windows 8.1 using SH3D 4.3 and Java 7 update 55 |
| Posted by okh at May 21, 2014, 10:17:40 PM |
Re: obj Transparency? Hi Pencilart, I have not noticed any wrong interpretation of transparency values in sh3d. Not obj/mtl interpretation, not texture interpretation. 1) did you check the .mtl file that accompanies the .obj file? Correct transparency should be set as d value under the transparent material. Eg. d 0.0 (=fully transparent - invisible)2) did you check the texture file (if you use one - png/gif) to see whether it still has transparency after export? ok |
| Posted by pencilart at May 21, 2014, 11:58:11 PM |
Re: obj Transparency? the mtl says: #Produced by Art of Illusion 3.0, Wed May 21 16:44:58 EDT 2014 newmtl Default_Texture Kd 0.23 0.23 0.23 Ks 0 0 0 Ka 0 0 0 illum 1 Still no joy. Hopefully I will be able to attach a screenshot: ---------------------------------------- ---------------------------------------- |
| Posted by okh at May 22, 2014, 10:15:32 AM |
Re: obj Transparency? Your .mtl file (the material: Default_Texture) does not seem to contain reference to a texture graphics file. e.g: map_Kd xxxx.pngor transparency, e.g: d 0.5Therefore I guess there must be something in how AoI exports. I have practically no experience with AoI, but can the settings be changed to include the texture file in the export - or something? Failing that, you could try to add transparency (e.g. d 0.5) to the .mtl file yourself, like this: #Produced by Art of Illusion 3.0, Wed May 21 16:44:58 EDT 2014ok |
| Posted by pencilart at May 22, 2014, 3:21:51 PM |
Re: obj Transparency? ok, n/m. I figured it out. chalk that up to not making models for many months. |
| Posted by pencilart at May 26, 2014, 10:11:50 PM |
Re: obj Transparency? Therefore I guess there must be something in how AoI exports. I have practically no experience with AoI, but can the settings be changed to include the texture file in the export - or something? I just saw your reply after I had posted saying, never mind. I might try to edit the mtl file as you said. But one thing with Windows 8, which is very annoying: Once you edit a file in an app, Windows 8 automatically assigns that app to open as the default for that file. Then to correct the problem, you have to take quite a few steps, which is the annoying part. In AOI, this is in the exported .obj: and this is in the .mtl file: Anyway, here is the chandelier after I finally remembered that I have to rename all things transparent to (without the quote marks of course) "sweethome3d_window_pane" ![]() And this is the chandelier as rendered by Art Of Illusion: http://www.storm-artists.net/view/136785 (I know that sh3d's renderer won't give the same results) P.S. I tried to edit the .mtl but that did not make a difference...That's ok. |
| Posted by okh at May 28, 2014, 12:58:29 PM |
Re: obj Transparency? Nice chandelier. Glad it worked. But now you have me confused . It seems transparency can be achieved in two ways. Either
ok PS. Win is a strange beast. If it weren't for some vital software, I ditch it in a sec. However, if you open-with / drag-drop your .mtl files into an editor (Notepad/PSPad), surely the default doesn't change (?) |
| Posted by pencilart at May 28, 2014, 3:48:47 PM |
Re: obj Transparency? I had forgotten that transparency only works if the item is named sweethome3d_window_pane I'm not sure about the mtl file, I've never looked at it to compare. Editing the mtl file for transparency does not work for some reason. Dunno if that has something to do with what software was used to create the item or not. Right now, the mtl files and obj files are not assigned to any software on Windows 8, and as far as I know it should stay that way. But when you edit such files, Win8 will assign that app as default. SO annoying. So, Okh, have you ever done any 3d modeling yourself? If you haven't, try it! :-) |
| Posted by Puybaret at May 28, 2014, 9:12:54 PM |
Re: obj Transparency? sweethome3d_window_pane is just a way to set a shape as transparent. It was introduced in an old version of Sweet Home 3D before the MTL file and d parameter were supported. In the current version, its main drawback compared to d parameter in a MTL file is that it's fixed to 0.5 and that you can't change its appearance in the furniture Furniture materials dialog box. When changing individual materials wasn't available, it was handy because when you changed the color of the window, only its frame was changed and the pane remained uncolored. But in version 4.3, changing the material of a window pane won't have any effect, something that looks more buggy because it's not necessary for backward compatibility. I just fixed it in the Beta 15 of the version 4.4. I am wondering whether sweethome3d_window_mirror_xxx (reflection) can also be achieved with .mtl. It seems that "illum 3" in MTL file format could match the mirror effect, but I didn't investigate further when I programed the first mirror effect. The good thing with introducing special names for shapes, is that it can be easily supported in file formats afterwards.Conclusion: pencilart, using d parameter works, but mixing it with sweethome3d_window_pane name won't change transparency value. Hum, maybe I should fix that too! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sree.arun.kr at May 28, 2014, 10:16:25 PM |
Re: obj Transparency? Some times transparency need to be assigned manually in Sweet home 3D Try these steps, 1. Make/design your model at any 3d-modeling software 2. Apply transparency texture(color=black&white) to it( use *.png only to work with SweetHome3D). 3. Align UVW mapping. 4. Export as .obj(wavefrot OBJ) or .3ds (check Transparency texture must be added in the same folder ). 5. Import exported obj/3ds file in sketch-up/any other 3d model viewing application to check transparency map working or not.If transparency does not load you failed to create model correctly(Need re creation). 6. If transparency working correctly then Import 3d model as furniture in Sweet-home-3D. 7. Select imported furniture, go to Furniture -> Modify in main menu 8. Select materials radio button in color& texture, then click Modify 9. Select model material(your transparent object material) then select Texture radio button and click browse button. 10. In the new window click Import button & browse, open your texture map and click OK for all windows. ![]() *10. If object don't have a texture file, fully transparent like glass then select color radio button and select white color in modify Furniture material window. 11. Now render your image. TIP. If you want to hide(invisible in render) a particular part of an object then use my texture. ![]() (This file consist zero color pixel). ![]() ---------------------------------------- ![]() |
Current timezone is GMT Sep 30, 2026, 7:49:07 PM |
