Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Multi-color wall |
| Print at Sep 6, 2026, 10:27:49 AM | View all posts in this thread on one page |
| Posted by shimoda at May 5, 2014, 4:37:26 PM |
Multi-color wall Hi, I need to design a new bathroom that needs to have tiles up to 120 cm from the floor for most of the walls and in 2colors ( I want a dark stripe behind the basin and the shower) and up to 190cm behind the shower. Can anyone tell me how to "paint" walls in a free way? I have seen some demos around of bathrooms with part of a wall covered with mosaic while all the remaining wall area was white. Thanks |
| Posted by hal9000 at May 5, 2014, 7:09:06 PM |
Re: Multi-color wall There are three approaches which can be used separately or together to achieve the desired effect: 1) divide a wall in more than one segment horizontally, so you can choose a different texture for each segment 2) use more than one level (adjusting its properties) so vertically part of the wall is for the level 0, the upper portion for the level 1, and so on 3) simply put a thin box with the desired texture "glued" to the wall in the correct place, just as it were a painted paper Regards. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 6, 2026, 10:27:49 AM |
