Print at Sep 29, 2026, 7:51:07 PM
Posted by DM5 at Apr 10, 2014, 6:11:51 AM
SH3D Not Recognizing DAE files
I've downloaded the model in the link below, opened it in SketchUp and exported it as a DAE file. When I open the Import Furniture window in SH3D, click Choose Model and find the file, the model's file (which clearly has the ".dae" extension) is grayed out as if SH3D is seeing it as an unsupported filetype. I've checked the "two-sided" box in options and tried copy and pasting the model into a new SketchUp window and exporting it from there and still haven't had any luck.
This is the first time I've used SH3D in about a year so maybe I just forgot a step; however, I never experienced this problem in the past. If it helps, I'm using the latest version of java and I'm working from a Macbook Pro with Mavericks.
https://3dwarehouse.sketchup.com/model.html?id=1e17e4a971564c75b022c94235bc8601
Posted by Puybaret at Apr 10, 2014, 10:38:12 AM
Re: SH3D Not Recognizing DAE files
Sweet Home 3D only checks supported extensions and doesn't analyze the content of files to make them selectable or not in its file chooser.
Maybe you use the Mac App Store version of Sweet Home 3D which is able to import only zipped files because of the sandbox security imposed by Apple. If it's the case, just zip the .dae file (with its textures if there are any) to import your 3D model. In case you didn't know, Mac OS X lets you create easily a .zip archive from the files selected in the Finder with the File > Compress menu item.
Posted by DM5 at Apr 11, 2014, 6:30:00 AM
Perfect answer. I was previously using the version downloaded off the website and the problem started after I started using the App Store version. Thanks for all the help, definitely wouldn't have figured out it was due to the version I was using.
Posted by Puybaret at Apr 11, 2014, 10:26:43 AM
Fortunately, you had the good idea to describe your computer wink
The message describing the supported file formats at the first step of the furniture import wizard was updated accordingly for the Mac App Store version, but as you knew this tool already from the free version, you probably didn't pay attention.
