Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: How to install SweetHome 3d on website |
| Print at Sep 10, 2026, 7:48:02 AM |
| Posted by Just_MAX at Sep 14, 2014, 10:07:58 AM |
Re: How to install SweetHome 3d on website Did it, thanks for pointing in right direction |
| Posted by Just_MAX at Sep 26, 2014, 5:40:42 PM |
Re: How to install SweetHome 3d on website I found PDF saving function doesn't work in my case, same as creating photo with date and time parameters, any clues what is wrong? |
| Posted by Puybaret at Oct 7, 2014, 3:09:33 PM |
Re: How to install SweetHome 3d on website - If you want Print to PDF feature, you have to set enablePrintToPDF applet parameter to true, and add iText-2.1.7.jar signed library to jars list (in the applet parameters as well as in the JNLP file). - If you want photo creation feature, you have to set enableCreatePhoto applet parameter to true, and add sunflow-0.07.3i.jar signed library to jars list. - If you want video creation feature, you have to set enableCreateVideo applet parameter to true, and add jmf.jar signed library to jars list. - If you want Export to SVG feature, you have to set enableExportToSVG applet parameter to true, and add freehep-vectorgraphics-svg-2.1.1b.jar signed library to jars list. Look at the Online version on this web site for a real world example (requires that you are logged in). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Just_MAX at Oct 8, 2014, 5:57:12 AM |
Re: How to install SweetHome 3d on website Did it before, but keep receiving errors about jnlp files mismatch (checked - it was same, files cache renewed, java cache disabled) And it worked after i sent you a message. Strange thing |
| Posted by efodi at Feb 20, 2020, 11:32:26 AM |
Re: How to install SweetHome 3d on website Hi! I have installed Java Version 8 Update 241 for using Sweet Home 3D online version, but i still receive the following error: Unable to load resource: http://www.sweethome3d.com/lib/SweetHome3DApplet.jar If i try independent to download the .jar i have no problem with it. It looks like only the site it self has problem with his own .jar. I'm using a Win10 with IE11. Could somebody please help me here? Thank you! |
Current timezone is GMT Sep 10, 2026, 7:48:02 AM |
