Print at Sep 19, 2026, 10:07:39 PM View all posts in this thread on one page
Posted by mohamed2015 at Apr 2, 2014, 2:18:36 AM
how to put listello on the wall???
can any one tell me how to put listello on the wall pls want to put it Crosswise
Posted by hansmex at Apr 2, 2014, 12:45:43 PM
Re: how to put listello on the wall???
Mo,
If by "listello" you mean a narrow band of tiles, this is the easiest way:
1 - import the texture; make sure you give it the correct height in inches or centimeters;
2 - apply the texture to a box that has the same height as the texture;
3 - make the box as wide as you need, and give it the correct elevation;
4 - place it directly in front of the wall.
Posted by mohamed2015 at Apr 2, 2014, 11:41:57 PM
hello mr hans first thank you for reply to me but second if am do what you did told me that will make a shadow when am will make the picture 3d and am not want the listello tile make a shadow am want it be on the wall direct not in front of the wall
Posted by hansmex at Apr 3, 2014, 1:07:46 AM
Mo,
Let me explain again...
If you want a band of tiles 10 cms high (or 4 inches), make sure that your texture is 10 cms high, and that your box is 10 cms high.
Now give your box the correct length, say 250cms.
It is important that the box is as thin as possible, and that you place it flush against the wall. This way it looks as part of the wall, and will not cast a shadow.
