Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rounded Roof? |
| Print at Oct 5, 2026, 8:02:07 PM | View all posts in this thread on one page |
| Posted by RogerTE at Mar 22, 2014, 12:07:28 PM |
Rounded Roof? Have made a small sports centre design for a local sports club's planning application. However my design shows it having a normal ridged roof, but the planners want it to have a rounded roof (5metres at eaves, rising to 7m at centre - overall width between walls 20m). Is it possible to show the two end walls being rounded? - not too worried about showing actual roof, just the walls. Thanks Roger |
| Posted by hansmex at Mar 22, 2014, 3:16:58 PM |
Re: Rounded Roof? Roger, You'll have to share your design if you want an answer.... Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by RogerTE at Mar 23, 2014, 10:32:22 AM |
Re: Rounded Roof? Hans, Have copied photo to Paint and have drawn curved lines curved top to the end walls Hope it shows what is required. It is becoming standard in this country for sports halls to have curved roofs, which is a bit unfortunate because it usually requires deeper rafters, making building taller. Thanks Roger |
| Posted by hansmex at Mar 23, 2014, 11:57:19 AM |
Re: Rounded Roof? Roger, This one's relatively easy. 1 - Select one of the end walls, and export it using 3D view --> Export as OBJ format --> Export selection; 2 - Import the wall, rotating it 90 degrees so that it lies flat on the ground; 3 - Using the wall as a guide, draw a wall along the curved side; include overhang, and apply textures; give the wall the height corresponding to the length of the roof; 4 - Export the wall, re-import it, rotate it. Voila, there's your roof. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by okh at Mar 24, 2014, 2:46:21 PM |
Re: Rounded Roof? Is it possible to show the two end walls being rounded? - not too worried about showing actual roof, just the walls. A wall with a rounded top is, I think, not possible to achieve automatically.
ok |
Current timezone is GMT Oct 5, 2026, 8:02:07 PM |
