Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SVG export fails |
| Print at Sep 19, 2026, 5:06:26 PM |
| Posted by ggrptr at Mar 4, 2014, 11:56:10 PM |
SVG export fails Hi! I can't get svg export to work on windows7 (x64) (oracle java version 7). I get this exception: java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at com.eteks.sweethome3d.tools.ExtensionsClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) I tried to add lib/freehep-vectorgraphics-svg-2.1.1b.jar to jars in the html source, but it still doesn't work. Can somebody help me to fix it? Thanks! |
| Posted by Puybaret at Mar 5, 2014, 9:51:51 AM |
Re: SVG export fails I tried to add lib/freehep-vectorgraphics-svg-2.1.1b.jar to jars in the html source, but it still doesn't work. Why would you add something which is already included with the program??? I feel you can't be helped if you don't tell us what you try to do and how you did it?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ggrptr at Mar 5, 2014, 5:57:35 PM |
Re: SVG export fails So, i simple view (over an apache server) the html page from the deploy folder, which containing the applet (after enable the svg export) . But the "export to svg" menu option throws a java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D exception. I thought that it helps to add lib/freehep-vectorgraphics-svg-2.1.1b.jar to jars list, but it doesn't. Sorry, but java isn't my strong suit, but i need this applet. In the eclipse debug it works. What do i wrong? |
| Posted by Puybaret at Mar 6, 2014, 10:36:35 AM |
Re: SVG export fails Reading SweetHome3DApplet documentation would have given you the answer: set enableExportToSVG parameter to true. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ggrptr at Mar 6, 2014, 7:53:02 PM |
Re: SVG export fails If it were not true, don't see the option. A more constructive reply? |
| Posted by Puybaret at Mar 6, 2014, 10:23:45 PM |
Re: SVG export fails If it were not true, don't see the option. Maybe, my English gets rusty, but I don't understand what you mean.A more constructive reply? A nicer reply from you would be really appreciated! I'm ok to help and I helped you. If you don't want it, help yourself, it's open source! By the way, explaining why you "need this applet" would be appreciated because sharing experiences is a part of the open source world too.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ggrptr at Mar 6, 2014, 10:55:35 PM |
Re: SVG export fails So, sorry for my english, i'm am in hurry with the last message, and I dont speak english, it's wery difficult to me.. What I tried to say: If i can start the export, I obviously that I allowed it, no? It's not too difficulty, sorry. Can you show me a working applet with SVG export function, or it does't work at all? |
| Posted by ggrptr at Mar 6, 2014, 11:29:21 PM |
Re: SVG export fails After enabling the export, it throws this exception: basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu: try again .. basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu: try again .. basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu_HU: try again .. basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu_HU: try again .. basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.swing.HomeTransferableList: try again .. basic: JNLP2ClassLoader.findClass: org.freehep.graphicsio.svg.SVGGraphics2D: try again .. basic: JNLP2ClassLoader.findClass: org.freehep.graphicsio.svg.SVGGraphics2D: try again .. java.lang.NoClassDefFoundError: org/freehep/graphicsio/svg/SVGGraphics2D at com.eteks.sweethome3d.swing.PlanComponent.exportToSVG(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.exportToSVG(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$38.call(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$38.call(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source) at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at com.eteks.sweethome3d.tools.ExtensionsClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) |
| Posted by Puybaret at Mar 7, 2014, 10:19:31 AM |
Re: SVG export fails I just try on the online version hosted on this server with no problem (the Export to SVG menu item appears only for logged in users). Did you sign freehep-vectorgraphics-svg-2.1.1b.jar? By the way, it would be still nice to share here why you need Sweet Home 3D applet. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ggrptr at Mar 15, 2014, 8:41:09 PM |
Re: SVG export fails At last I found it, the embedded jnlp file didn't conatined the right jars for the svg import. It was my fault, because I am inexperienced in this area .. Now, I have another problem. I don't need funriture models, but only doors and windows. What furniture and texture catalogs contains these? I downloaded the additionalFurnitureCatalog.zip, and it works, but in the catalog tree, the icons missed, replaced with a "missing image" icon.. What can I do with this? Thank You! |
Current timezone is GMT Sep 19, 2026, 5:06:26 PM |
