Print at Sep 10, 2026, 6:25:50 AM
Posted by SnakeGB at Mar 3, 2014, 7:21:30 PM
Cant save home
I just get this strange java error
Posted by Puybaret at Mar 3, 2014, 9:30:38 PM
Re: Cant save home
I wonder if it wouldn't be a similar error to this bug.
Can you try to remove from the plan the objects you imported one by one during the last session and see if you can save?
Posted by SnakeGB at Mar 3, 2014, 10:56:44 PM
Re: Cant save home
no joy,,
i even created a new building and put every object ive imported into it and it still saved and reopened
maybe the file just went currupt...
ill try on another pc see if it loads
Posted by SnakeGB at Mar 4, 2014, 12:57:16 PM
Re: Cant save home
wont work on another pc either
could this be a corrupt file?
Posted by Puybaret at Mar 4, 2014, 3:15:27 PM
Re: Cant save home
Probably. The strange thing is that you can open the .sh3d file. But maybe, there's an error at the very end of your file, in which case you should lose very little data once fixed. Please, send it to me so I can fix.
Posted by SnakeGB at Mar 5, 2014, 12:57:49 AM
applause   Re: Cant save home
Thanks works a treat smile
Posted by Alicelewis11 at Mar 21, 2014, 11:01:26 AM
Re: Cant save home
Hi Puybaret! Can you share here that how can i fix it.
Posted by Puybaret at Mar 21, 2014, 3:07:03 PM
Re: Cant save home
I wouldn't mind to share how to fix it, but it's too complicated at the moment for non programmers, so I prefer you send it to me. Maybe I'll publish the tools I use one day, but I prefer until now to fix it myself in case you discovered a bug. Most of the time it's actually due to a corrupted file nowadays.
