Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to Select all levels |
| Print at Aug 22, 2026, 2:30:23 AM | View all posts in this thread on one page |
| Posted by zizo_mosad at Mar 3, 2014, 11:27:05 AM |
How to Select all levels Hi I want to resize the whole building with every furniture in it. I used Advanced Editing plug-in but i have 3 levels and I don't know how to select them all! I've tried to Ctrl + A but this select the current level only. Any help |
| Posted by hansmex at Mar 3, 2014, 11:49:20 PM |
Re: How to Select all levels There is no way to select all levels at the same time. You will have to repeat the resize for every level. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by zizo_mosad at Mar 4, 2014, 3:53:43 PM |
Re: How to Select all levels I tried several times to resize every level but i never succeed because there are some walls appear in both levels. Is there any tool to resize obj file ? |
| Posted by hansmex at Mar 4, 2014, 4:05:46 PM |
Re: How to Select all levels When you export to OBJ format, then re-import, your design becomes an ordinary piece of furniture which you can resize easily. Only problem is that it has become one piece, so you can't work on the parts anymore. If you have walls appearing in more than one level, you could change the wall height, or the level height, so that walls appear only in the level where they belong. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by zizo_mosad at Mar 4, 2014, 4:59:28 PM |
Re: How to Select all levels I manage to do this by re-importing. Thank you @hansmex |
Current timezone is GMT Aug 22, 2026, 2:30:23 AM |
