Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problems with version 4.3 and Java 7 on Mac OS X 10.8 |
| Print at Aug 22, 2026, 4:16:46 PM | |
| Posted by the_patcher at Feb 23, 2014, 9:59:59 PM |
Problems with version 4.3 and Java 7 on Mac OS X 10.8 Hi, is it possible to run Sweet Home 3D version 4.3 with Oracle Java 7 installed on Mac OS X 10.8.5? Currently when I try to start the local application, I get a dialog saying I have to download Java 6 from Apple. But Oracle JRE 7 is already installed on my system as you can see from the terminal output: ~$ java -version java version "1.7.0_51" Java(TM) SE Runtime Environment (build 1.7.0_51-b13) Java HotSpot(TM) 64-Bit Server VM (build 24.51-b03, mixed mode) ~$ whereis java /usr/bin/java Java is the browser is disabled through the Java control panel. Any help is appreciated :) |
| Posted by Puybaret at Feb 24, 2014, 10:36:29 AM |
Re: Problems with version 4.3 and Java 7 on Mac OS X 10.8 You should use the Jar executable version of Sweet Home 3D. To ensure that the max memory setting will be enough, run it with the following command in the Terminal: java -Xmx2048m -jar /path/to/SweetHome3D-4.3.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by the_patcher at Feb 24, 2014, 7:11:58 PM |
Re: Problems with version 4.3 and Java 7 on Mac OS X 10.8Thank you very much :) I was blind ;) when I checked the files section on sourceforge yesterday. |
Current timezone is GMT Aug 22, 2026, 4:16:46 PM |
