Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Modify walls is greyed out |
| Print at Aug 21, 2026, 11:31:56 PM | |
| Posted by [email protected] at Feb 4, 2014, 10:25:02 PM |
Modify walls is greyed out The 'modify walls' menu choice is greyed out when I select the walls of my plan. When I click on a wall, all of the walls are highlighted in purple and arrows appear at each intersection. The plan is not locked. I am using a MacBook running OS 10.9.1, Sweet Home 3D version 4.3 and Java version 1.6.0_65. I have read the user manual and posts on this topic from 2010 and 2012. I apologize in advance since I'm probably missing something obvious. Thanks for any help you can provide! |
| Posted by Puybaret at Feb 5, 2014, 8:57:48 AM |
Re: Modify walls is greyed out I fear you encountered the following bug: sometimes, when you start to create levels in a home that is not empty, furniture and walls previously added are not assigned to the first level. As I couldn't reproduce this bug, I couldn't fix it but fortunately it happens very rarely. Please send me your file, and I'll fix it for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 11:31:56 PM |
