Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can´t make photografie |
| Print at Aug 21, 2026, 10:49:48 PM | |
| Posted by Remy0151 at Feb 3, 2014, 5:05:35 PM |
Can´t make photografie hallo, could use some help. I want to make some real photos of my architectural model, and later a video. My problem is that in the best-quality stage, the image calculation 400x600 pixels stops me again and again even at a resolution of approx. The model is also very detailed. It has about 500mb. What can be wrong? Or what can I do? I tried to give more main memory, but it doesn´t work i my opinion. I see in the Windows task manager, that the cache use only to 3mb. Mayby I do it not correctly, but I tried more scopes My laptop has Intel Core (TM) i7 processor and 6 GB of RAM, Windows 7 (64 bit) and an NVIDIA GeForce graphics card as GT330MM Thank you for your help |
| Posted by Puybaret at Feb 3, 2014, 7:13:33 PM |
Re: Can´t make photografie First, just to be sure what you run: Do you use version 4.3? If yes, does the 3rd line of the About dialog show 32 bit or 64 bit? Does the 2nd line show Java Web Start or not? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Remy0151 at Feb 4, 2014, 1:00:48 PM |
Re: Can´t make photografie Hallo, thanks for help. This was the reason, why it didn´t work. The old version! Thanks a lot! Best regards |
Current timezone is GMT Aug 21, 2026, 10:49:48 PM |
