Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Level 0 walls appear in every level |
| Print at Oct 1, 2026, 1:16:14 AM | |
| Posted by dorgan at Jan 24, 2014, 12:56:03 AM |
Level 0 walls appear in every level Love this software, which I just started using. Obviously I am new to it, but suddenly: 1) The walls from Level 0 are visible (in black not grey) in every level; 2) When I create a new level they appear as if by magic overlaid on the grey walls from the lower lever; 3) I am unable to edit or delete them. No doubt I'm doing something embarrassingly silly, but would appreciate guidance so I don't have to rebuild the 4 floor building from scratch again. |
| Posted by okh at Jan 24, 2014, 9:05:24 AM |
Re: Level 0 walls appear in every level 1) & 2) Your level 0 walls are probably higher than the level itself. Edit walls (select, right-click, modify walls) and/or level (click top tab) properties. 3) In the top left corner of the 2D view, there is a padlock to lock and un-lock the base-plan. Un-locking should let you edit walls. ok |
Current timezone is GMT Oct 1, 2026, 1:16:14 AM |
