Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: open side shed rendering |
| Print at Sep 20, 2026, 2:42:52 AM |
| Posted by scottsport at Jan 10, 2014, 2:48:12 AM |
open side shed rendering Hi all, I want to use SH3D to draw and design an indoor equestrian arena that has: 1. A roof with support columns at regular intervals but otherwise is open sides and one end 2. At the other end a residence under the same roofline 3. The residence is elevated above ground level by 60cm with a verandah I have drawn the residence - sans roof - but cannot figure out how to draw the rest of the arena. Any help would be appreciated. Thanks for a marvelous program as well. Certainly the best one out there so far as i can determine - and for free! |
| Posted by okh at Jan 10, 2014, 9:41:37 AM |
Re: open side shed rendering Pretty hard to tell without more information. Is the roof the problem? (Flat roof = flat elevated box). Or the columns? (Use boxes shaped as columns). Draw a room for the arena to add texture. You probably need to use several levels. ok |
| Posted by hansmex at Jan 10, 2014, 10:33:34 AM |
Re: open side shed rendering Is this what you are looking for? House & Horse ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by scottsport at Jan 10, 2014, 10:08:33 PM |
Re: open side shed rendering Thanks very much for the replies. I was a tad terse I suppose. Hansmex : Yes that is the idea except that the horse part has no sides - only columns at regular intervals to support the roof, and the residence part starts at verandah level. okh: Thanks - re arena - yes I think the 'furniture object' trick would look after the gable roof and the columns and setting up 2 levels (ground - verandah, and verandah - residence roof; which is the same roof line as for the arena) for the residence. Again - great to have this support. I have only been using the software for a day so I have a lot to learn! Tony Scott |
| Posted by scottsport at Jan 10, 2014, 11:54:03 PM |
Re: open side shed rendering I'll reply to me... Now have the roof and columns! thanks so much for the tips. Here is what I have so far. Just need to figure out how to add the verandah... ![]() |
| Posted by okh at Jan 11, 2014, 10:34:00 AM |
Re: open side shed rendering Simple solution - verandah = room with low, thin walls. ok PS - image link local - doesn't show |
| Posted by scottsport at Jan 21, 2014, 7:08:45 AM |
Re: open side shed rendering Thanks heaps to all. Hansmex, I cannot figure out how you gave the verandah a surface texture. Could you elaborate please? Thanks again. tony |
| Posted by hansmex at Jan 21, 2014, 7:22:55 AM |
Re: open side shed rendering Please study the example file I gave you. The veranda is just a room, and it's easy to gives rooms textures. Read the User's Guide or use the in-built Help. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by scottsport at Jan 21, 2014, 7:33:03 AM |
Re: open side shed rendering BTW - here is my project thus far. Still some work to do - adding the verandah roofs etc. Any advice is always welcome https://www.dropbox.com/s/4e0jiopj7tdqkj0/clermont%20plan%20layers%20copy.sh3d Thanks again for this marvelous software. tony |
| Posted by scottsport at Jan 21, 2014, 8:43:40 AM |
Re: open side shed rendering Thanks again, your file has the verandah as a room - how did you get the room to show a 'roof' which would be the same as a 'floor' from the POV of layer 1? I may have be way over-conceptualizing this way too much of course... |
Current timezone is GMT Sep 20, 2026, 2:42:52 AM |
