Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Sweet Home 3d Viewer limits ? |
| Print at Sep 20, 2026, 6:30:35 PM | |
| Posted by harvey186 at Jan 5, 2014, 1:52:59 PM |
Sweet Home 3d Viewer limits ? Moin, I have transfered my sh3d file, which has 48MB to my web server. It seems, that the file will load, but nothing is show. Is there a file size limit for the viewer ? You can check it here if you want: Haus |
| Posted by hansmex at Jan 5, 2014, 3:44:49 PM |
Re: Sweet Home 3d Viewer limits ? It shows and turns on my computer (Ubuntu 12.04 and Oracle Sun Java). If you want to speed things up, delete half the trees, or replace them with trees of the same kind as the tree next to the house. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jan 5, 2014, 4:15:51 PM |
Re: Sweet Home 3d Viewer limits ? The limits are what the viewer applet can view with 640 MB of memory, and… the patience of your users. Because, if it worked correctly on my computer, I wouldn't expect my web users to wait more than 10 minutes to view a 3D model of a home, how amazing it would look like. Maybe, you could remove or replace the biggest 3D model; for example, just the Rhododendron occupies 1/4 of your .sh3d file! Anyway, very nice house model ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by harvey186 at Jan 5, 2014, 4:21:12 PM |
Re: Sweet Home 3d Viewer limits ? Mhm, I think I will remove the plants. Thanks for your comments. |
| Posted by harvey186 at Jan 6, 2014, 6:34:50 PM |
Re: Sweet Home 3d Viewer limits ? OK, now I know the reason why I get only a white screen. It's a OS X related issue. I have tried it on 3 different machines with Leo, SnowLeo and Maverick. All are only showing a white screen after the house is loaded. When I use my virtual XP or Win7 or Linux everything works fine. |
| Posted by Puybaret at Jan 6, 2014, 6:50:08 PM |
Re: Sweet Home 3d Viewer limits ? I tried on Lion with Java 7u45 with no problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by harvey186 at Jan 7, 2014, 12:33:47 PM |
Re: Sweet Home 3d Viewer limits ? I'm using Java 6xxx :( |
| Posted by harvey186 at Jan 7, 2014, 1:13:04 PM |
Re: Sweet Home 3d Viewer limits ? I have just installed 7u45 on my Mavericks and I get the same result ... only a white screen :( It seems, that the viewer isn't working well. On some Mac machines only a white screen and on Windows machines a virus error message. That's very worst, because I want use the web page an model to sell my home. |
| Posted by harvey186 at Jan 8, 2014, 12:21:59 PM |
Re: Sweet Home 3d Viewer limits ? Here my log from the terminal: Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/batik-svgpathparser-1.7.jar Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/Loader3DS1_2u.jar Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/macosx/java3d.jar 3D [dev] 1.6.0-pre8-daily-experimental daily Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D$1$1.componentResized(Unknown Source) at java.awt.AWTEventMulticaster.componentResized(AWTEventMulticaster.java:160) at java.awt.Component.processComponentEvent(Component.java:6331) at java.awt.Component.processEvent(Component.java:6285) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:705) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) Java-Plug-in 10.45.2.18 JRE-Version verwenden 1.7.0_45-b18 Java HotSpot(TM) 64-Bit Server VM I don't know what "Missing Application-Name: manifest attribute for: " menas, but I think that's the reason, why I only get I white screen on my Mac |
| Posted by Puybaret at Jan 8, 2014, 7:56:42 PM |
Re: Sweet Home 3d Viewer limits ? The error must come from the NullPointerException, not the Missing Application-Name warnings. Could you test if the Beta version 4.3 available here (24.6 MB) fixes your issue? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by harvey186 at Jan 10, 2014, 11:10:35 AM |
Re: Sweet Home 3d Viewer limits ? Sorry, for late reply, I was out for some days. I have just tested it with Firefox and Safari. On both browsers the house is show :) Many thanks. |
| Posted by Puybaret at Jan 10, 2014, 4:09:44 PM |
Re: Sweet Home 3d Viewer limits ? Thanks for your feedback and happy it works now. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 6:30:35 PM |
