Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Change level of a surface |
| Print at Aug 22, 2026, 5:03:58 PM | |
| Posted by A.Bahr at Dec 30, 2013, 11:36:48 AM |
Change level of a surface i cant find how to move a surface a little higher to link two stairs and build a 180 deg. stairs. i think it's impossible and i just had to add a cubic object and size it as my need. is it right? |
| Posted by hansmex at Dec 30, 2013, 10:17:01 PM |
Re: Change level of a surface Learn how to Add a Level. I think that will solve uour problem. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by A.Bahr at Dec 30, 2013, 10:37:05 PM |
Re: Change level of a surface thanks again. no . i can't define elevation for a surface and i think it's not possible in this version. if it's possible please tell me how can i do it. |
| Posted by hansmex at Dec 31, 2013, 12:29:26 AM |
Re: Change level of a surface Solution 1 - You can give all furniture objects any desired elevation. So, insert a flat box as a halfway floor and give it the desired elevation. Then, give the second staircase the same elevation as the halfway box. Solution 2 - If you want to use a floor, do as follows: - insert a new level; - give that level an elevation that's half the height of your room; - on the bottom level insert the first stairs; - draw a room without a ceiling on the new level; - staircase two goes on the halfway level and reaches the floor of the next floor. Success. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by A.Bahr at Dec 31, 2013, 3:30:46 AM |
Re: Change level of a surface thanks you a lot. it's perfect. |
Current timezone is GMT Aug 22, 2026, 5:03:58 PM |
