Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: adding texture to a box |
| Print at Sep 10, 2026, 12:28:06 AM | View all posts in this thread on one page |
| Posted by petefastfeet at Dec 18, 2013, 11:11:25 PM |
adding texture to a box Hello all, When I add a texture to a box, it stretches the texture image to the size of the box face, as opposed to replicating the image....any thoughts what I am doing wrong? |
| Posted by Puybaret at Dec 19, 2013, 5:11:48 PM |
Re: adding texture to a box Textures applied to the box provided with Sweet Home 3D behave differently according to the way you selected the textures: - if you apply a texture globally on the box, i.e. by selecting a texture directly from the Modify texture dialog box, then the size of the texture will be taken into account and will be truncated or repeat itself, depending on the size of the box - if you apply a texture on one or more faces of a box, i.e. through the Furniture materials sub dialog box, then the texture will be resized to fit the given face(s) of the box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by petefastfeet at Dec 19, 2013, 11:14:26 PM |
Re: adding texture to a box Thanks for the quick response. I see now how it works, thanks. |
| Posted by ndorigatti at Jul 15, 2018, 11:30:43 AM |
Re: adding texture to a box Hi, sorry for resuming this but I have a question on this... I want to draw wood pieces for an attic and those have the texture of different angle of different textures on sides, so I would like to create a box and repeat the texture on their sides, so what I'm asking is if I can do with blender or other software, because I tried but Did not manage to do, reading this post seems that is due to the sweet home behaviour and not on my models, am I right? |
| Posted by Puybaret at Jul 15, 2018, 2:48:26 PM |
Re: adding texture to a box You can't prepare texture mappings in Blender that won't stretch textures in the exported OBJ file when you resize your imported piece. But you could use 3 (or more) boxes instead of one in Sweet Home 3D, one for the 4 front/top/back/bottom sides, and 2 (or more) thin ones for the left and right sides. Once grouped, the textures on the boxes will behave as you expect it when you resize the group (see the file attached to this post). ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 10, 2026, 12:28:06 AM |
