Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: need help with my roof |
| Print at Sep 14, 2026, 2:52:23 AM | |
| Posted by harvey186 at Dec 17, 2013, 4:30:32 PM |
need help with my roof Hi together, I know, there are a lot of other question regarding roof creation. But I have a very difficult roof to build. I have a 8 corner house and it has a 36 degrees roof. The roof is a "saddle roof". Every side is on the top 14 meters long and on the gutter end 5,50 meters long. The saddle is on one side 7.50 meters high and the other side is 60 meters high. I have created the rooms and I can show you, but I don't know how to upload my obj here. I hope the obj is download able from this link here. Roof.obj Would be great if someone can show me how the create this kind of roof. Many thanks Harvey |
| Posted by okh at Dec 17, 2013, 6:15:58 PM |
Re: need help with my roof Hi, .obj file works well. Cool house, but I am glad I'm not your builder... :-) Either you can use 3d modelling software, or you can look at hansmex' roof-guide: http://www.sweethome3d.com/slopingCeilingGuide.pdf In short, it is probably doable by using separate SH3D drawings of slanted walls in the correct angle which you later export to .obj files and re-import and rotate. But it is not all that straightforward. For this kind of roof, I would prefer 3d modelling software that can work with accurate dimensions. But learning how to use such software will require a bit of patience.... ok |
| Posted by harvey186 at Dec 22, 2013, 10:27:33 AM |
Re: need help with my roof https://drive.google.com/file/d/0BwmPWemR6lELWFVqLXF6R3ZjWTA/edit?usp=sharing a new link to my house project. I still hope, that someone find a solution for me :) |
Current timezone is GMT Sep 14, 2026, 2:52:23 AM |
