Print at Sep 6, 2026, 8:49:03 AM
Posted by pabloyepes at Oct 3, 2013, 8:50:38 PM
White sky
I am using version 4.1 on Linux. When I render an image of the whole building with an aerial view in level 4, the sky always comes out white. In the 3D properties I tried to use a texture of various skies, and using just a dark blue color. In all cases, on the rendering the sky looks white. I have also changed the brightness, but it does not change the result. Any ideas?
Posted by Puybaret at Oct 5, 2013, 9:35:09 AM
Re: White sky
I guess it's white because you view a part of the generated sky in direction of the sun.
As stated in the help:
If you selected a color for the sky in the 3D view pane or if the current mode is Aerial view, a sky image computed according to the hour of the day is used for the rendering of the sky. If you chose a texture for the sky, that texture will always be used in Virtual visit mode whatever the selected hour.
So try to use a texture image for the sky.
Posted by pabloyepes at Oct 12, 2013, 1:11:23 PM
Re: White sky
I also tried with a texture, but it still shows a white sky. Any other ideas?
Thank you
