Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Java-Error "LoadLibrary failed with error 126:..." on startup |
| Print at Aug 17, 2026, 6:07:44 AM | |
| Posted by barflo at Sep 8, 2013, 4:53:17 PM |
Java-Error "LoadLibrary failed with error 126:..." on startup Hi All, I want to use Sweethome 3d on my win8 pc. I already used it before updating from win7 to win8 without any problems. Since the update to win8 i get the following error message when starting sweethome 3d: "LoadLibrary failed with error 126: The specified module could not be found." I get the same err message both the offline and the online version of sweethome 3d. I think it is an java problem, not a win8 or sweethome 3d issue. But maybe someone out there has a similar problem. Please help me THX, |
| Posted by Puybaret at Sep 8, 2013, 9:09:16 PM |
Re: Java-Error "LoadLibrary failed with error 126:..." on startup I would uninstall / reinstall Java. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by barflo at Sep 9, 2013, 6:07:20 PM |
Re: Java-Error "LoadLibrary failed with error 126:..." on startupI reinstalled java and sweethome 3d. Didn't help. But... The Problem is fixed. I installed a newer version of the graphic card driver. It seems, that the old one did not work correctly with win8. I'm using a ATI radeon HD3650. the driver, which works has the version 8.970.100.7000. THX for your help |
Current timezone is GMT Aug 17, 2026, 6:07:44 AM |
