Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Mirrored drawing |
| Print at Sep 27, 2026, 9:02:02 PM | |
| Posted by [email protected] at Aug 13, 2013, 4:54:06 PM |
Mirrored drawing I have a 2-D complete drawing that is finished. The thing is that I need to mirror¹ it and don't know how. Please how do I do this? ¹) upper right corner will end up as upper left corner after mirroring. |
| Posted by hal9000 at Aug 13, 2013, 5:57:20 PM |
Re: Mirrored drawing Well, if you don't need to make changes after mirroring, then you can do this: 1) install (if not installed) the "copy as new furniture" plugin 2) select everything in your design, then use the "copy as new furniture" option 3) open a new document and paste the copied desing, which will appear as a single object 4) edit the object and mark "mirrored shape" checkbox That's all. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by hansmex at Aug 13, 2013, 6:16:18 PM |
Re: Mirrored drawing Rolf, Download and read the Plug-in Tutorial. (here) Download and install the Advanced Edit plug-in. Use that plug-in to mirror your design, in such a way that you can still edit it. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by hal9000 at Aug 13, 2013, 6:56:32 PM |
Re: Mirrored drawing Rolf, Download and read the Plug-in Tutorial. (here) Download and install the Advanced Edit plug-in. Use that plug-in to mirror your design, in such a way that you can still edit it. Hans Does Advanced Edit plugin mirror? I think it only rotates. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by Puybaret at Aug 13, 2013, 8:50:55 PM |
Re: Mirrored drawing No, it mirrors if you use a negative value for width or height. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hal9000 at Aug 13, 2013, 9:28:33 PM |
Re: Mirrored drawing No, it mirrors if you use a negative value for width or height. ![]() Oh! I see. Well, you can always learn new things. ![]() ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 27, 2026, 9:02:02 PM |
