Print at Sep 19, 2026, 10:35:17 PM View all posts in this thread on one page
Posted by Markedavis at Jul 22, 2013, 10:02:52 PM
Locked out
Something happened and I cannot select any walls or objects. Any ideas on how to unlock rather than starting all over again?
Posted by hal9000 at Jul 23, 2013, 12:50:17 AM
Re: Locked out
It sounds like you have locked the base plan, although that only affects to walls, windows, doors, stairs and objects which have been marked as "part of base plan" so if in that case you still should be able to select normal objects.
Anyway, look at the plan menu, there is a option which says "lock base plan" or "unlock base plan", in the second case just click the option to unlock the plan.
Posted by Markedavis at Jul 23, 2013, 3:07:42 PM
Re: Locked out
Odd- It was unlocked so I locked per the instructions and then unlocked again. No difference. I can add new walls and objects, and add dimension measurements but the original [which was very detailed] is no longer selectable. This all happened after I put my MAC pro to sleep and then after awake the plan was not longer editable. Thanks.
Posted by Markedavis at Jul 23, 2013, 3:14:44 PM
Re: Locked out
WOW- I clicked on the detailed window to see if I could select a table and after double clicking the table [width,depth,height, with visible checked] the main plan became totally selectable again. Very odd behavior. Thanks for your help I am working properly now. :)
Posted by Puybaret at Jul 23, 2013, 3:54:11 PM
Re: Locked out
Do you use levels?
Posted by Markedavis at Jul 24, 2013, 5:12:13 PM
Re: Locked out
I did not use levels. But after double clicking in the object detail window the plan became editable again. I will check to see if this happens every time I put the MAC pro to sleep. I will post the results here.
I use OSX 10.8.4 with a MacPro laptop 2.9 GHZ intel Core i7 with 8GB of Ram.
