Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Insulation |
| Print at Sep 6, 2026, 10:46:09 AM | View all posts in this thread on one page |
| Posted by Babsi at Jul 11, 2013, 4:47:49 PM |
InsulationHi! Does someone know how to include insulation on the walls? I know that you can part the wall into two pieces (same width). But is there any way to get a wall for example with 25cm bricks and 20cm insulation? Thanks Babsi |
| Posted by hansmex at Jul 12, 2013, 6:40:27 AM |
Re: Insulation Babsi, No, there's no simple way to do that. However, you could draw double (or triple) walls, using exact coordinates, then use Modify walls -> Pattern in plan to distinguish between the walls. Personally, I draw my cavity walls 30 cms thick, which is the standard in my country (10 cm outside wall, 10 cm cavity/insulation, 10 cm inside wall). Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 10:46:09 AM |
