Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installation OK Cannot Save |
| Print at Aug 20, 2026, 3:26:42 AM |
| Posted by RicReeves at Jun 13, 2013, 1:19:52 PM |
Installation OK Cannot Save Hi all, I was wondering if anyone could help with the error I am getting!? Every time I try to save in any directory (local or network) I get the following error: "Can't Save home in "C:\3d\home.sh3d" RecorderException: Can't save home C:\3d\home.sh3d java.io.IOException: Access is Denied" Any ideas on where to start? Using Windows 8 and the latest Java and SweetHome3D. Had to install the SweetHome3D.l4j.ini to make it work at all. Many thanks! |
| Posted by Puybaret at Jun 13, 2013, 2:24:42 PM |
Re: Installation OK Cannot Save Either C:\3d folder doesn't exist, or you don't have the right to write in that folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jun 13, 2013, 2:25:15 PM |
Re: Installation OK Cannot Save Did you try in another folder like your desktop? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by RicReeves at Jun 13, 2013, 2:27:51 PM |
Re: Installation OK Cannot Save Hi guys, thanks for the speedy response. I created the c:\3d folder and can browse to it in the save dialog box. I have full permissions on the folder (I am an administrator) and have given 'Everyone' full permissions on the folder. Same error if I try to save to Desktop, and my Documents folder. |
| Posted by Puybaret at Jun 13, 2013, 2:29:12 PM |
Re: Installation OK Cannot Save Really strange... And can you save an empty document at least? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by RicReeves at Jun 13, 2013, 2:30:47 PM |
Re: Installation OK Cannot Save Can't save a blank document either :( |
| Posted by Puybaret at Jun 13, 2013, 2:32:18 PM |
Re: Installation OK Cannot Save What did you write in your SweetHome3D.l4j.ini file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by RicReeves at Jun 13, 2013, 2:32:41 PM |
Re: Installation OK Cannot Save There is no need to give java permission to write to the folder(s) I suppose? |
| Posted by RicReeves at Jun 13, 2013, 2:33:54 PM |
Re: Installation OK Cannot Save The ini file is just the Default Direct3D one as downloaded from the site. Contents: # Place this file in the same directory as SweetHome3D.exe file to always run Sweet Home 3D with DirectX -Dj3d.rend=d3d -Dsun.java2d.d3d=true -Dsun.java2d.noddraw=false -Dsun.java2d.ddoffscreen=true -Dsun.java2d.ddscale=true -Dcom.eteks.sweethome3d.deploymentInformation=DirectX |
| Posted by Puybaret at Jun 13, 2013, 2:34:12 PM |
Re: Installation OK Cannot Save There is no need to give java permission to write to the folder(s) I suppose? That would be a little tedious for many users... ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 3:26:42 AM |
