Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Cannot select walls or furniture after creating rooms |
| Print at Sep 28, 2026, 2:30:04 AM | View all posts in this thread on one page |
| Posted by susirene at Jun 5, 2013, 4:48:54 PM |
Cannot select walls or furniture after creating rooms I have had a great time using SweetHome 3D to create a model of my new house and am excited about knowing where all my furniture will go when I move, but I've run into an issue after creating rooms. I essentially built the entire floor plan - walls, windows, doors, and furniture - for both 1st and second floor, then went back and created the rooms/floors/ceilings. After creating the rooms, I can no longer select any of the previously-created walls, doors, windows, or furniture on the FIRST floor. No problem on the second floor. I have locked and unlocked the base plan and it makes no difference. I can add furniture to the first floor and am able to select that with no problem. When I pull up the "select object" option the furniture/walls/windows/doors aren't even on the list to select. Help? |
| Posted by Puybaret at Jun 5, 2013, 5:02:00 PM |
Re: Cannot select walls or furniture after creating rooms Please send me your file to see if can reproduce this bug here and fix your file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jun 7, 2013, 11:45:16 PM |
Re: Cannot select walls or furniture after creating rooms susirene, your login was lost because of a crash in the forum database tonight. Please, register again if you want to write new messages. Sorry for the problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 2:30:04 AM |
