Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: 2D view from side with dimensions? |
| Print at Sep 6, 2026, 10:28:37 AM | |
| Posted by geco73 at May 28, 2013, 11:31:45 PM |
2D view from side with dimensions? Hello, Is there any possibility to create side views from the house with dimensioning. Such views are needed for the workman and the needed information (such as window hight, position, ...) would be available. Thanks! |
| Posted by Puybaret at May 29, 2013, 11:35:32 AM |
Re: 2D view from side with dimensions? Sorry there's no side views using a parallel projection in Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by geco73 at May 29, 2013, 4:14:54 PM |
Re: 2D view from side with dimensions? What would you suggest as alternative? Is there a possibility to get dimensions on the 3D view? How about exporting my plan and importing it into a professional cad used by my architect. Is then the information there for side views? Thanks! |
| Posted by hal9000 at May 29, 2013, 4:19:04 PM |
Re: 2D view from side with dimensions? I think a possibility would be to export the full home as .OBJ and then import it back as furniture, rotating it conveniently leaving the side you need to measure as the upper side. That way it could be seen from the 2D top view, what I don't know is if it would look correctly or not... ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 6, 2026, 10:28:37 AM |
