Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: I'm newbie. is this normal? |
| Print at Aug 24, 2026, 11:52:57 PM | View all posts in this thread on one page |
| Posted by oleyfe at May 28, 2013, 9:42:33 PM |
I'm newbie. is this normal? in the 3D view of my house some walls are transparent, is this normal? and also I can not create pictures, all somebody can tell me why and if you have any solution to this? ![]() |
| Posted by Puybaret at May 28, 2013, 10:57:23 PM |
Re: I'm newbie. is this normal? First time that somebody reports this strange issue... Could you check if there's any update of the driver for your graphics card? What is your system? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at May 28, 2013, 11:19:13 PM |
Re: I'm newbie. is this normal? I had a similar thing happening (4.0, Win8): a wall becoming semi-transparent. The disturbance, _I think_, came from: - a window/door model (self made, .dae), AND / OR - walls overlapping between levels (first level going well into the second, including walls and presumably rooms with ceilings too). Unfortunately I didn't save the file. ok |
| Posted by oleyfe at May 29, 2013, 12:33:28 AM |
Re: I'm newbie. is this normal? the graphics card driver is the most up to date .... I have W7 32-bit, 1GB RAM and also I have the version 4.0 but with previous versions the same thing happens |
| Posted by Puybaret at May 29, 2013, 11:32:46 AM |
Re: I'm newbie. is this normal? Could you send me your file? Maybe you did something unexpected? By the way, the photo creation should at least work correctly at the two best quality levels. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by oleyfe at May 29, 2013, 4:17:36 PM |
Re: I'm newbie. is this normal? I just sent the file ... I hope that if have slucion |
| Posted by Puybaret at Jun 4, 2013, 1:03:04 AM |
Re: I'm newbie. is this normal? Sorry but I couldn't reproduce your issue on my computer. ![]() In a future version (not the one released tonight), a major update of the Java3D library should appear. You'll have to check if it works better at that moment. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 24, 2026, 11:52:57 PM |
