Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: adding wall openings |
| Print at Sep 6, 2026, 10:11:26 AM | View all posts in this thread on one page |
| Posted by shellbug at May 28, 2013, 10:07:42 AM |
adding wall openings how do I add a wall opening for doorways with no doors? I tried door frame but the opening does not go all the way to the ceiling like some of mine do in my home. |
| Posted by hansmex at May 28, 2013, 3:59:42 PM |
Re: adding wall openings Michelle, Use an invisble box. (file) Don't forget to tick door/window when importing it. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at May 29, 2013, 12:02:52 PM |
Re: adding wall openings If the opening doesn't goes high enough, why didn't you try to increase the height of the opening accordingly? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MarioSambol at Jan 29, 2026, 2:08:17 PM |
Re: adding wall openings Both ways are good. |
| Posted by MarioSambol at Jan 29, 2026, 2:09:54 PM |
Re: adding wall openings For wall openings or niches, it is good to have various invisible objects of different shapes. |
| Posted by Keet at Jan 30, 2026, 8:19:47 AM |
Re: adding wall openings Replies to a question from more than a decade ago? Much has changed in Sweet Home 3D since then. The "answer" from dictatorxmas is cleverly disguised SPAM. He changed the url in the quote. Always be careful with replies from members where the post count is 1. I have reported several of these as spam, this one from dictatorxmas and others where spam urls are in the signature. That said, the solution Hans offered with the invisible box is still valid and very useful. In this case however I would simply cut out a piece of wall since the opening must be all the way to the ceiling. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Indigo_Solo at Jan 30, 2026, 7:27:26 PM |
Re: adding wall openings In case the set of solutions result still useful for somebody, here is what I would do: Add a door frame. Go to Furniture options, by pressing Ctrl+E. Change door frame height and width, even elevation, if necessary. A service hatch would be useful, too. Have a nice day. |
| Posted by Indigo_Solo at Jan 30, 2026, 7:28:35 PM |
Re: adding wall openings OH! and make the door frame invisible, by changing the material. |
| Posted by Keet at Jan 30, 2026, 7:45:17 PM |
Re: adding wall openings In case the set of solutions result still useful for somebody, here is what I would do: Add a door frame. Go to Furniture options, by pressing Ctrl+E. Change door frame height and width, even elevation, if necessary. A service hatch would be useful, too. OH! and make the door frame invisible, by changing the material. Yep, that works too and is the same as using an invisible box imported as Door or window.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 6, 2026, 10:11:26 AM |
