Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Where does SH save its .obj-list? |
| Print at Aug 19, 2026, 3:19:08 PM | |
| Posted by truffe2miel at May 28, 2013, 12:24:07 AM |
Where does SH save its .obj-list?Hello! I'll have to change my computer quite soon, and so have to transfer all my data to another HD. I'm looking for the file/place where Sweet Home saves all the objects and textures a user can add to the list... Who knows? ![]() |
| Posted by Puybaret at May 28, 2013, 12:27:36 AM |
Re: Where does SH save its .obj-list? Please read this thread. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by truffe2miel at May 28, 2013, 8:09:43 AM |
Re: Where does SH save its .obj-list? Thank you very much Other questions : - On my computer, there are sub-folders named "textures" & "furnitures". Those are empty, while my 1.200 or so importations are all jammed into the main folder "Sweet Home 3D" - everything seems to have lost it's categorization, textures & furnitures are also mixed. => Is this normal? I've found by chance how to create a new category in the furniture list, but I still have to manage each item individually to change it's category (meaning I can't select 15 items at a time and drag them or right-click to change property for example. => is this normal too? |
| Posted by Puybaret at May 28, 2013, 9:51:20 AM |
Re: Where does SH save its .obj-list? everything seems to have lost it's categorization, textures & furnitures are also mixed. The categorization and other data is saved in the preferences.xml file found in this folder too. That's why you must copy it too. You don't have to copy the work folder, and don't worry about textures and furnitures sub-folders too if they are empty.=> Is this normal? For my own information, does Sweet Home 3D still work correctly with a big amount of imports like yours? I can't select 15 items at a time and drag them or right-click to change property for example. Yes, it's not possible to change multiple pieces of the catalog at the same time in the current version.=> is this normal too? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by truffe2miel at May 28, 2013, 11:41:12 PM |
Re: Where does SH save its .obj-list? The categorization and other data is saved in the preferences.xml file found in this folder too. Thank you :) I had hoped I could change the categorization of my objects directly in the backup list, but it seems that won't do either - no matter ;) For my own information, does Sweet Home 3D still work correctly with a big amount of imports like yours? Yes, it does very well! The 3D view sometimes simply shuts down (or closes the whole program) when overloaded with too detailed objects (mainly some specific flowers or very fine textures with lots of motifs). All in all, SH is just a gemstone in the see of 3D-softwares: easy to understand and use, easy to handle, nice almost professional results. I just love it :D Yes, it's not possible to change multiple pieces of the catalog at the same time in the current version. Thanks. Well, maybe this could be included in further reflecting sessions? ;) |
| Posted by Puybaret at May 29, 2013, 11:46:19 AM |
Re: Where does SH save its .obj-list? One tip though: the category of each object is stored in the preferences.xml file. You could edit this file with any text editor, and change the text between > and < in the lines starting by <entry key="furnitureCategory#, like: <entry key="furnitureCategory#4">Other</entry><entry key="furnitureCategory#4">My category</entry>The problem is that it won't be easy to recognize each piece of furniture since they are identified by a number and not by their name (the name you gave to an imported object is defined in the entries with a key starting by furnitureName#). Before doing any tests be sure to create a backup of your eTeks/SweetHome3D folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 3:19:08 PM |
