Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to import autocad .dxf or .dwg files to .obj |
| Print at Sep 6, 2026, 10:11:28 AM | View all posts in this thread on one page |
| Posted by dlabril at May 27, 2013, 6:21:04 PM |
How to import autocad .dxf or .dwg files to .objHello, I need to import models from autocad so I supose that I need to transform them to .3ds or .obj files. Could you recommend me any tool for this task? I have seen that Autodesk 3Ds Max can transform from dxf to 3ds but I haven't any license to do this. Thanks in advance. Diego |
| Posted by hansmex at May 28, 2013, 1:14:22 AM |
Re: How to import autocad .dxf or .dwg files to .obj http://en.softonic.com/s/3ds-dxf-converter ? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by dlabril at Jun 1, 2013, 1:25:19 PM |
Re: How to import autocad .dxf or .dwg files to .obj Thanks a lot for your help, Problem is that these programs only convert from dxf or dwg to an image format (not to a obj file or 3ds necessary to work with sweethome). |
| Posted by bwechner at Aug 22, 2016, 1:19:45 PM |
Re: How to import autocad .dxf or .dwg files to .obj Did you find a solution to this? I mean it looks like a nice app but I have my house all drawn up in DXF files and would like to import them as the baseplan, not recreate ... |
| Posted by dorin at Aug 24, 2016, 9:28:35 PM |
Re: How to import autocad .dxf or .dwg files to .obj For blueprint You need to import a png file. I use this way to solve it: AutoCAD(dxf/dwg)->export as pdf -> convert in png with GIMP. Then import as background in SH3D. Of course I must redraw all wall & etc. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Angelian at Sep 5, 2017, 9:58:53 AM |
Re: How to import autocad .dxf or .dwg files to .obj thanks for sharing. |
Current timezone is GMT Sep 6, 2026, 10:11:28 AM |
