Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Global rotate |
| Print at Sep 6, 2026, 10:11:31 AM | View all posts in this thread on one page |
| Posted by HornyPotter at Apr 30, 2013, 10:49:37 PM |
Global rotate Hey to all Sweeters, is it possible to do a global rotate? For example, I have a complex home design and I would like to do something like: Ctrl-A (to select all objects) then rotate all the objects as being 1 I have tried the 'group furniture' but that doesn't do what i want... thanks! hp |
| Posted by hal9000 at Apr 30, 2013, 11:43:12 PM |
Re: Global rotate Did you try the Home Rotator plugin? ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by HornyPotter at May 1, 2013, 1:36:21 AM |
Re: Global rotate Now i did! i downloaded it... installed it... but it does not appear in the Plan menu... yes... i did quit and restarted SH3D... I'm running 4.0 |
| Posted by hal9000 at May 1, 2013, 1:52:30 AM |
Re: Global rotate That's weird. Well, what language are you using? I'm using Spanish and in my case the "plan" menu is called "plano", but the plugin seems to ignore the localization and then it adds its own "plan" menu with the options to rotate, so I have two menus "plano" and "plan". Anyway, this plugin allows 90 degrees rotations only, which I don't know if would be good for you or you need a more customizable angle. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 6, 2026, 10:11:31 AM |
