Print at Aug 20, 2026, 6:59:25 AM
Posted by baggins at Apr 19, 2013, 12:58:09 AM
Replacing textures
When designing a home it is sometimes useful to change the texture of the walls to see the effect of using another type of brick or using some other kind of material.
I have found no other way of doing this apart from replacing the texture for every individual wall. (I know that I can select multiple walls, but with a multilevel home, this can be quite tedious).
I thought of doing a search and replace of the texture in the sh3d file, but couldn't quite figure out the structure of the file...
Any tips?
TIA
Posted by Puybaret at Apr 19, 2013, 11:56:07 AM
Re: Replacing textures
There's a need for multiple selection across multiple levels, but I didn't find the good feedback to show this kind of selection to the user yet. If it's technically possible, what about displaying some kind of indicator in the tab of the levels where some items are selected?
The structure is simple: it's a zip file with a Home entry for the home data and numeric entries (0, 1, 2, 3...) for the 3D models files and the images used in the designed home.
So, you should create a backup of your sh3d file, open it with a zip utility (maybe changing its extension by zip first), and edit each of the entries until you find the image you want to replace. The biggest problem is that zip entries don't have any extension so it's not easy to guess if it's some text or an image. sad
Posted by hansmex at Apr 19, 2013, 2:35:08 PM
Multiple selection across more than one level could be achieved by holding the SHFT or CTRL-key while selecting. This is already possible in the furniture list (SHFT = sequential selection, CTRL = non-sequential), but it could be made possible also in the 2D window. SHFT would select only on one level, CTRL would enable selections over more than one level.
To show which selection is being made, my solution (for which I asked a few years ago) would be to introduce a furniture list with two tabs: (1) furniture and (2) walls/rooms.
Posted by baggins at Apr 19, 2013, 5:33:25 PM
Thanks for the feedback.
I found out that for the particular home I am working on, the texture that I used for the outside of the walls is actually stored three times in the sh3d file...
As for selecting multiple walls: for this to work correctly, all walls need to be drawn in the same direction, if one only wants to change one side of the walls (as in my case).
