Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Bug or mistake? |
| Print at Sep 27, 2026, 3:08:17 PM | |
| Posted by hansmex at Apr 10, 2013, 5:09:18 PM |
Bug or mistake? Emmanuel, Designing a house, I come across a fault that I cannot correct. I'm not sure if it's a mistake on my part, or a bug in the program. The design calls for a ceiling with two holes in it, which function as skylights. I have made three "rooms", the biggest one with ceiling, the two smaller ones without ceiling. Nevertheless, the entire room is shown without a ceiling. Maybe you can have look at it? House Plan du Roc Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Apr 10, 2013, 7:03:04 PM |
Re: Bug or mistake? Hans it looks like a bug that happens from time to time with complex ceilings. Actually, Sweet Home 3D tries to compute the intersection between a ceiling and the floor at the upper level, and sometimes the program isn't able to display this shape if it's too complex. In your case, it can be fixed easily by moving the top left corner of the largest room you draw at level 0. You'll see that as soon as you place this point at walls corner (it's not at that place in the version you shared), the ceiling will appear. In one word, complex design requires more precision from the designer. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 11, 2013, 4:12:39 PM |
Re: Bug or mistake? Solved. Thanks for your help. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 27, 2026, 3:08:17 PM |
