Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Testing.... |
| Print at Sep 27, 2026, 11:24:58 PM | |
| Posted by nigec at Mar 31, 2013, 3:14:37 PM |
Testing.... This is my first attempted at figuring out how to import items and export the scene so it rendered correctly externally, basically I made the office walls in sections, ie window, door and lights. I used Sketchup free and Thea Render for the rendered image If any one wants the walls let me know. |
| Posted by Puybaret at Apr 1, 2013, 12:49:42 PM |
Re: Testing.... Very nice, and how does it render in Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by nigec at Apr 7, 2013, 1:55:26 PM |
Re: Testing.... It renders ok, I was having some issues with faces flipping on a full render I found if I just added meshes rather than duplicating the sections fixed that problem I need to figure out a better way of doing the lights |
| Posted by hansmex at Apr 7, 2013, 3:05:09 PM |
Re: Testing.... The best way I found to add light to a room, without disturbing the general light settings, is to insert a large white or incandescent light, say 100x100 cms, at a height of approx. 100 cms and with a strength of 10-20%. This lights up a large space without causing shadows. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by nigec at Apr 7, 2013, 4:22:17 PM |
Re: Testing.... Can you name a mesh as a light source? in the light units I have a simple planes as emitters, actually in the render it has the planes on the outside hidden and the lights inside are a fake emitters to give the glow |
| Posted by hansmex at Apr 7, 2013, 5:19:48 PM |
Re: Testing.... The solution I gave is based on SH3D. I'm not familiar with other programs. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by nigec at Apr 7, 2013, 8:00:58 PM |
Re: Testing.... Yes I know sorry, what I was trying to say was can we do custom lights in SH3D, I saw a thread about importing lights as 3DS but the links were dead |
| Posted by hansmex at Apr 7, 2013, 9:51:41 PM |
Re: Testing.... You cannot import or export light. - If you export only a light bulb, then on importing SH3D will tell you that it doesn't recognize the model. - If you export light bulbs in combination with other models or walls, the model will be imported, but the light is lost. So, if you need light, you will have to specify this manually in an OBJ or MTL file. As far as I know, there is no manual that explains how to do this. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 27, 2026, 11:24:58 PM |
