Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: "Can't open home" (Windows 7) |
| Print at Sep 7, 2026, 9:20:58 AM | |
| Posted by anagrom_ataf at Mar 31, 2013, 1:03:33 PM |
"Can't open home" (Windows 7) Hello, first of all thanks a lot for this great and powerful program! I have a problem, opening saved files on a PC running Windows 7. If the "*.sh3d" contains only walls and rooms, there is no problem. If it contains windows or doors, the file can't be opened. The error message says "Can't open home 'test.sh3d'"/ "Konnte Wohnung 'test.sh3d' nicht öffen". On a PC running Windows XP, exactly the same file can be opened without any problems. Can you help me to solve this bug? |
| Posted by Puybaret at Apr 1, 2013, 12:52:21 PM |
Re: "Can't open home" (Windows 7) How many times did you try? Does it really happen as soon as you add a piece of furniture, a door or a window to your plan? Does it happen also if there's just one piece? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by anagrom_ataf at Apr 1, 2013, 2:34:18 PM |
Re: "Can't open home" (Windows 7) I tried it several times and on different PCs. (Another PC running Windows 7 created the same problem.) At first I saved a plan containing only walls, closed the program and opened the file again. As soon as I add to this same plan or a door or a window or a piece of furniture, I can't open this file again. There is no difference, if there are more pieces or only one. |
| Posted by Puybaret at Apr 1, 2013, 3:09:43 PM |
Re: "Can't open home" (Windows 7) I never heard about such an issue. Really strange. Could you send me that file please? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Apr 1, 2013, 5:45:01 PM |
Re: "Can't open home" (Windows 7) Thanks for the test files you sent me. I had no problem to open them under Mac OS X and Windows 7. You should know that SH3D files are zip files, and wonder if it's possible that some antivirus software or a zip utility could interfere with Sweet Home 3D, even if I never heard about such a problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by anagrom_ataf at Apr 2, 2013, 8:05:01 PM |
Re: "Can't open home" (Windows 7) Deinstalling 7Zip, installing WinRAR, deactivating Avira AntiVir doesn't change anything... I'll use the other computer! Thank you nevertheless! |
| Posted by shad at Aug 15, 2013, 2:02:20 PM |
Re: "Can't open home" (Windows 7) Hello. I have same problem on two computers with windows 7 prof x64. The file can't be opened. The error message says "Can't open home 'test.sh3d'". The file was created on this computer. On a PC running Windows 2003, the same file can be opened without any problems. P.S If the "*.sh3d" contains only walls and rooms, there is no problem. If I add a piece of furniture, a door or a window - the file can't be opened. |
Current timezone is GMT Sep 7, 2026, 9:20:58 AM |
