Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: bad rendering |
| Print at Sep 7, 2026, 9:33:22 AM | |
| Posted by Llewelyn at Mar 29, 2013, 11:52:31 AM |
bad rendering I noticed this in the 3D view. Part of the floor pattern from the level above shows through the ceiling in virtual visit mode. It doesn't seem to do this in a photo created from that view, so I guess not critical, but I don't see why it's happening even so, the levels look correct: level 0: height 8', level 1: height 8', floor 1', elevation 9'. screen grab basic rendered photo ![]() |
| Posted by Puybaret at Mar 29, 2013, 9:46:26 PM |
Re: bad rendering Could you check whether you don't have twice a room defined at the upper level? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by nigec at Mar 30, 2013, 12:55:56 AM |
Re: bad rendering I had something similar earlier tonight and it was the room defined twice, no idea how it happened |
| Posted by Llewelyn at Mar 30, 2013, 9:04:36 AM |
Re: bad rendering The room was not defined twice, I just checked. levels are 96" with 12" floor, set 108" apart. If I move the next level up to elevation 108.125" the problem goes away. I guess maybe if the ceiling had a texture, not a colour, it might not do that. seems the texture of the floor above is going all the way through the floor, not half-way as the wall textures do. |
| Posted by Puybaret at Mar 30, 2013, 7:50:48 PM |
Re: bad rendering This could be also due to computing errors in the intersection between the room ceiling and the floor above. I saw a few cases where it didn't work as expected, for complex ceilings. Could you send me the file that caused a problem if you still have it? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Llewelyn at Mar 31, 2013, 7:02:24 PM |
Re: bad rendering I do have it, I'll send it. |
Current timezone is GMT Sep 7, 2026, 9:33:22 AM |
