Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate Room |
| Print at Sep 6, 2026, 7:07:26 AM |
| Posted by OMMBoy at Mar 26, 2013, 9:32:56 PM |
Rotate Room Hello! I'm attempting to put together a floorplan for my company using existing rooms which I've measured and entered into SH3D. Each room is a separate file. Also, a few of the rooms are not exactly square/rectangular, but have angled walls (you might say the rooms are "triangular"). Is it possible to select the floorplan from one file, paste it into a second file, and rotate the rooms to align with each other? If this is not currently possible, will this room rotation feature be available in a future release? Thank you for your help! And keep up with the great work! Chris |
| Posted by Puybaret at Mar 27, 2013, 10:43:50 AM |
Re: Rotate Room You should use the Advanced Editing plugin described in this document . ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Mar 27, 2013, 1:21:39 PM |
Re: Rotate Room Chris, If you install the RotateHome plug-in, there's a nice trick that's not documented (yet). Because the Levels feature didn't exist in SH3D at the time the plug-in was written, it was impossible to foresee how the plug-in would behave. It turns out that you can rotate the background plan and models per individual level. This offers the possibility to import your model on a second level, rotate it to the correct position, then copy it to the level where you assemble your building. By the way, you should note that the RotateHome plug-in rotates in 90 degree steps only. Maybe it's a good idea to ask the developer of the plug-in to add a feature to rotate in 1 degree increments. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by OMMBoy at Mar 28, 2013, 4:25:45 AM |
Re: Rotate Room Thank you very much for your input, Emmanuel and Hans! I will download and install the plugin first thing in the morning when I get to work! And I will definitely ask the developer of the plugin to add the 1-degree increments feature as I believe it will be quite valuable. Chris |
| Posted by klgan at Mar 29, 2013, 10:46:59 AM |
Re: Rotate Room Oh great! I log in to ask this question and it is already here :-) I have downloaded the plugin n extracted it. But the installation guide in the pdf file seems does not apply to Ubuntu OS. My SH3D installation is very simple. I downloaded the 53.7mb file and than extract it. A new folder named SweetHome3D-4.0 appear. Inside this folder I click the SweetHome3D script file and the program start, and it been working fine. Now the directory structure where the plugin folder is located is as this:- SweetHome3D-4.0/jre1.6.0_43/plugin The extracted RotateHomePlugin contain 2 folders named dist & src. I place these folders in the plugin folder, and restart SH3D. And nothing happen, the two additional options are not showing in the Plan menu. I must be doing something wrong. Need guidance please... :-) Thank you Gan |
| Posted by hansmex at Mar 29, 2013, 11:51:30 AM |
Re: Rotate Room Gan, Under Ubuntu do the following to install a plug-in: - if necessary unzip it - in Nautilus (the file browser) type CTRL-H to show the hidden files - go to .eteks/sweethome3d/plugins (if the plugins directory doesn't exist yet, make it) - move the plugin files to the plugins directory - start SH3D Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by klgan at Mar 30, 2013, 6:33:34 PM |
Re: Rotate Room Hi Hans, Thank you. With the CTRL-H in the Home directory, I finally see the .eteks/sweethome3d/ :-) Okay I created the plugins folder and place the unzipped RotateHomePlugin folder in it. But I don't see the additional items in the Plan menu. So instead of the whole thing, I took just the two sub-folders from inside the RotateHomePlugin folder, and put it in the plugins folder. Still nothing. And I continue by just copying the items in the sub folders or from sub-sub folders into the plugin folder. Each time restarting the SH3D. Still no menu :-), what am I doing wrong? Okay when you say ".. - move the plugin files to the plugins directory", do you mean the whole folder or just a file from inside this folder? Because when I unzip the downloaded RotateHomePlugin.zip, it produce a RotateHomePlugin folder, and contain inside it few more folders and sub-folders and files. Do I copy the whole unzipped RotateHomePlugin folder into plugins folder or just a files or two from inside it? How many times have I typed "folder/s" here... :-) oh, feeling dizzy already.. :-D Sorry and Thanks Gan |
| Posted by [email protected] at Mar 27, 2015, 1:52:48 AM |
Re: Rotate Room I am still having trouble with the ROTATION you mentioned. When I put on a new level, I can still only rotate grouped furniture... and only by 15 degree increments. How do you rotate the entire room? I can't get walls to rotate either. And of course you already mentioned the Rotate Plan only does 90 degrees. Using Advanced Editing Plugin... I don't see how to rotate at all. |
| Posted by GAthena at Oct 27, 2016, 2:06:39 AM |
Re: Rotate Room I’m having the same issue, has anyone come up with a working solution? I have tried unzipping the plug-in and copying the content into Home/.eteks/sweethome3d/plugins. I have restarted SH3D, but still I don’t see the new plug-in options. If anyone knows the answer to this problem, please respond. Thanks in advance. |
| Posted by dorin at Oct 28, 2016, 3:27:16 PM |
Re: Rotate Room Here is mine content of plugins folder: - 2016 AdvancedEditing.sh3p - 15:25 AdvancedSettings_PhotoRendering-1.3.sh3p - 2014 CalculateWallsAria.sh3p - 2015 CopyAsNewFurniture-1.2.sh3p - 2010 CopyStyle.sh3p - 15:25 CreatePhotoWithRenderer-1.2.sh3p - 2013 DimensionLines.jar - 15:25 ExportToHTML5-1.1.sh3p - 2009 ExportToSH3F-1.0.sh3p - 2015 RenameFurniture-1.2.sh3p - 2015 RoomAreaSum.sh3p - 2015 RoomPerimeter.sh3p - 2009 RoomVolume.jar - 2009 RotateHome.sh3p - 2016 ShapeGenerator-1.1.sh3p - 2015 UtilityPlugin.sh3p Whit AdvancedEditing You will have under Menu Edit-> Rotate.. & other options active after You select something or All. Whit RotateHome You will have under Menu Plan->Rotate; That will rotate 90 deg entire plan even You don't select something. To verify if the plugin is installed go to Menu About->Library. You must have the .sh3p file not the content of zip archive of that. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 6, 2026, 7:07:26 AM |
