Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Ocatgon v3 |
| Print at Sep 27, 2026, 11:23:57 PM | View all posts in this thread on one page |
| Posted by Llewelyn at Mar 19, 2013, 8:47:18 PM |
Ocatgon v3 version 3, calculated correct dimensions for a regular octagon and changed the way I drew it slightly, the roof still isn't perfect but now the same roof section doesn't quite fit all of it Also got some better textures and did a bit more decorating, but ran out of inspiration for a couple of rooms. Ah, and I see I left one patio door in the wrong place. Can't select a wall section without moving it, as it covers the entire section on the plan. ![]() |
| Posted by Puybaret at Mar 19, 2013, 9:47:09 PM |
Re: Ocatgon v3 Can't select a wall section without moving it It's time to use the Select Object contextual menu to select the object where you right clicked in the plan. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 11:23:57 PM |
