Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: sloping floors (and roofs...) |
| Print at Aug 21, 2026, 3:16:24 AM | |
| Posted by Llewelyn at Mar 16, 2013, 9:10:40 PM |
sloping floors (and roofs...) Just wondering if I can draw a room with a sloping floor, so that say one side is at elevation zero and the other side at about 4ft. I have a design for a house with no steps, uses ramps to get between split-level floors, thus being suitable for wheelchair users. I'd quite like to model it in 3D to see how it looks :) roofs are a similar problem - having realised that rooms have ceilings even though you can't see them in aerial view, I can get my head round that. creating sloping roofs is not so obvious so I hope this will happen in a later version! I did look at the tutorial which says to use "plan > edit room points" but I don't see that option in the plan menu. Ah well I only just downloaded and started to play, maybe doing the octagonal house as a first project was ambitious :) |
| Posted by hansmex at Mar 16, 2013, 10:50:24 PM |
Re: sloping floors (and roofs...) Austin, If you look here, you will find several tutorials. I suggest you start with the plug-ins tutorial. It will show you -amongst others- how you can edit room points. Sloping floors aren't possible, unless you use a workaround. The simplest way would be to use a large triangle. Sloping ceilings are supported; check the roof tutorial. Also, the User's guide offers a lot of information, as does the built-in Help. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Llewelyn at Mar 17, 2013, 8:57:54 AM |
Re: sloping floors (and roofs...) Thanks for the info. I'll study those - I did look around a bit in the help and the forum. I guess "sloping floors" would go along with roofs as a feature in a later version :) |
| Posted by Llewelyn at Mar 17, 2013, 11:15:03 PM |
Re: sloping floors (and roofs...) Well, I more or less got the roofs right... they don't quite join up correctly, partly because it's not quite a regular ocatgon, so there are 2 slightly different (and no doubt subtly wrong) roof sections. Can I post screenshots? |
| Posted by jlturriff at May 27, 2013, 6:57:45 AM |
Re: sloping floors (and roofs...) Hans, I have installed the appropriate plugins and I followed the slopingCeilingGuide, and was able to make a roof, but on one side (I think it was the side on the ground before rotation) there is a rectangle at right angles to the roof that won't go away. Only the side toward the roof is visible; from the other side it's transparent. The roof was created from a single sloping wall; it has no peak. ( /= ) How can I get rid of the rectangle? |
| Posted by hansmex at May 27, 2013, 9:54:21 AM |
Re: sloping floors (and roofs...) Leslie, Since SH3D v4.0, you should change one step. Don't use Tools --> Copy as new furniture. Instead use directly 3d view --> Export to OBJ format --> Export selection. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by jlturriff at May 28, 2013, 9:54:34 AM |
Re: sloping floors (and roofs...) Okay; thanks very much. |
Current timezone is GMT Aug 21, 2026, 3:16:24 AM |
