Print at Aug 22, 2026, 7:44:05 PM
Posted by AnonDMV at Mar 8, 2013, 6:16:25 PM
Problem Starting Online Version
When trying to start the online version, I get the following error: ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
Don't see this in the FAQ or another thread. Runing IE9 with Java 10.7.2. Thanks for any help.
Posted by Puybaret at Mar 9, 2013, 4:12:12 PM
Re: Problem Starting Online Version
Do you get this error when you try to run the Online version at this page, or when you try to run your own version.
Posted by AnonDMV at Mar 14, 2013, 5:07:39 PM
I get the error when trying to run the Online version at "this page" (http://www.sweethome3d.com/SweetHome3DOnline.jsp). I have not attempted to install or use a download version. Thanks.
Posted by StNff at Mar 16, 2013, 1:55:59 PM
I Do get this error when I try to run my own version. And another question. In what directory should I have catalogs of furniture and textures?
Posted by StNff at Mar 17, 2013, 6:51:05 PM
P.S. ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DViever
Posted by Puybaret at Mar 18, 2013, 8:58:38 AM
StNff, I don't understand why you report an issue with com.eteks.sweethome3d.applet.SweetHome3DViewer in a subject about the Online version (i.e. com.eteks.sweethome3d.applet.SweetHome3DApplet class). What are you trying to do?
Posted by StNff at Mar 18, 2013, 1:58:25 PM
<font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
I have compiled applet (ANT utility). I have this error when trying to start SweetHome3DApplet.html.
http://osnova-mebel.com/3d/SweetHome3DApplet.html
Posted by StNff at Mar 18, 2013, 4:49:55 PM
confused   Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
P.S.
I have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
I think I had another error yesterday.
Posted by StNff at Mar 24, 2013, 12:50:59 PM
I had JDK 7.
Now I have JDK 5 (As in the instructions).
Log compilation:
D:\1>ant javaWebStart
Buildfile: D:\1\build.xml
build:
[mkdir] Created dir: D:\1\build\classes
[javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
alse for repeatable builds
[javac] Compiling 2 source files to D:\1\build\classes
[javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
[javac] Compiling 193 source files to D:\1\build\classes
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 261 files to D:\1\build\classes
[zip] Building zip: D:\1\build\SweetHome3D.jar
[delete] Deleting directory D:\1\build\classes
application:
[zip] Building zip: D:\1\build\SweetHome3DStandalone.jar
[move] Moving 1 file to D:\1\build
furniture:
[zip] Building zip: D:\1\build\Furniture.jar
textures:
[zip] Building zip: D:\1\build\Textures.jar
help:
[zip] Building zip: D:\1\build\Help.jar
jogl-java3d:
[zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar
java3dLibraries:
[mkdir] Created dir: D:\1\deploy\lib\windows\i386
[zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\windows\x64
[zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\i386
[zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\x64
[zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\macosx
[zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar
javaWebStart:
[mkdir] Created dir: D:\1\build\JNLP-INF
[copy] Copying 1 file to D:\1\build\JNLP-INF
[zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar
[zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar
[copy] Copying 6 files to D:\1\deploy\lib
[input] Enter Passphrase for keystore:
1111
[signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё  эрщЄш єърчрээ√щ Їр
щы)
BUILD FAILED
D:\1\build.xml:238: jarsigner returned: 1
Total time: 1 minute 40 seconds
Tell me, what's the problem?
Posted by Puybaret at Mar 24, 2013, 2:39:58 PM
Reading the README.TXT file coming with the source file would have given you the answer:
Note that the last part of the Ant targets javaWebStart, applet and viewer requires a passphrase for keystore to sign the deployed jars. For security reasons, the required file keys.keytool isn't provided with this source code. You'll have first to generate this file and choose a passphrase, with the following command run in the directory where you uncompressed this archive:
keytool -genkey -keystore keys.keytool -alias SweetHome3D
Posted by StNff at Mar 25, 2013, 8:56:58 AM
I'm sorry, all my fault my English, and lack of knowledge about programming.
I constantly have to use the Google translator.
I have a successful build.
But the error is still there (ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet).
Could this error cause,
alse for repeatable builds?
Posted by Puybaret at Mar 25, 2013, 4:42:11 PM
The ClassNotFoundException means Java didn't find the class, i.e. it wasn't in the jar files you gave, or the jar files are not found.
Posted by StNff at Mar 26, 2013, 5:43:28 PM
I had a warning:
<b>build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds</b>
So I decided to try Ant 1.7, building failed. I decided to try Ant 1.9 - building successful, but I still have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
I see no error in the log that generates this error. You may have a different opinion. I therefore complete log.
<b>D:\1>ant javaWebStart
Buildfile: build.xml
build:
[javac] Note: D:\1\src\com\eteks\sweethome3d\swing\JPEGImagesToVideo.java uses or overrides a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
application:
furniture:
textures:
help:
jogl-java3d:
BUILD FAILED
D:\1\build.xml:118: Problem creating zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar (╤шёЄхьх эх єфрхЄё  эрщЄш єърчрээ
√щ яєЄ№) (and the archive is probably corrupt but I could not delete it)
Total time: 1 minute 13 seconds
build:
application:
furniture:
textures:
help:
jogl-java3d:
java3dLibraries:
javaWebStart:
111111
[signjar]
[signjar] Warning:
[signjar] The signer certificate will expire within six months.
[signjar] Signing JAR: D:\1\deploy\lib\SweetHome3D.jar to D:\1\deploy\lib\SweetHome3D.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar to D:\1\deploy\lib\SweetHome3DJavaWebStart
Bootstrap.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\batik-svgpathparser-1.7.jar to D:\1\deploy\lib\batik-svgpathparser-1.7.jar as S
weetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\freehep-vectorgraphics-svg-2.1.1.jar to D:\1\deploy\lib\freehep-vectorgraphics-
svg-2.1.1.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\iText-2.1.7.jar to D:\1\deploy\lib\iText-2.1.7.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\jmf.jar to D:\1\deploy\lib\jmf.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\linux\i386\java3d.jar to D:\1\deploy\lib\linux\i386\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\linux\x64\java3d.jar to D:\1\deploy\lib\linux\x64\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\macosx\java3d.jar to D:\1\deploy\lib\macosx\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\sunflow-0.07.3g.jar to D:\1\deploy\lib\sunflow-0.07.3g.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\windows\i386\java3d.jar to D:\1\deploy\lib\windows\i386\java3d.jar as SweetHome
3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\windows\x64\java3d.jar to D:\1\deploy\lib\windows\x64\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[echo] deploy dir ready for ftp
BUILD SUCCESSFUL
Total time: 2 minutes 56 seconds</b>
Posted by Puybaret at Mar 26, 2013, 9:07:32 PM
Forget warnings, it's not the problem.
Posted by StNff at Mar 29, 2013, 7:49:27 AM
My "SweetHome3DApplet.html" has an entry:
var jars = "lib/SweetHome3DApplet.jar,lib/Loader3DS1_2u.jar,lib/batik-svgpathparser-1.7.jar,lib/jnlp.jar"
But the directory does not contain SweetHome3DApplet.jar
In the folder there SweetHome3D.jar, all right?
Posted by Puybaret at Mar 29, 2013, 10:06:08 AM
How do you think it could work if you provide SweetHome3D.jar when the applet expects a SweetHome3DApplet.jar file??? I fear you mix up some concepts and try to run an application as an applet, but it won't work this way. sad
Applets and Java applications are not the same even if they can share some classes. Spending more time on learning about applets might help.
Posted by StNff at Mar 29, 2013, 12:26:40 PM
Then please tell me where to get this jar file and why it is missing after a successful build.
Posted by Puybaret at Mar 29, 2013, 1:37:07 PM
Run "ant applet"
Posted by StNff at Mar 31, 2013, 8:33:57 AM
Thank you very much! You have given me great help! This morning, studying build.xml I myself realized that asking the wrong target when building. Read your reply and smiled my carelessness. Everything works. However, the program has a red body instead of models, there is no icon. I set the parameters as follows:
furnitureCatalogURLs:"catalog/furnitureCatalog.zip,lib/additionalFurnitureCatalog.zip",
furnitureResourcesURLBase:"catalog/models/",
texturesCatalogURLs:"catalog/texturesCatalog.zip",
texturesResourcesURLBase:"catalog/textures/".
I will study the materiel on.
Posted by StNff at Apr 1, 2013, 10:15:46 AM
Have you encountered such a problem? On some computers do not display a tree of elements and textures, on the other they are available. In what could be the problem? In the version of browser?
Posted by Puybaret at Apr 1, 2013, 12:27:27 PM
StNff, you ask a lot but don't share that much with the community. It would be nice to present yourself and explain why you need to build a online version of your own.
Posted by StNff at Apr 1, 2013, 1:22:24 PM
I should explain, I have a small furniture factory and I want to be able to make a presentation of my models in this wonderful program.
Posted by Puybaret at Apr 2, 2013, 12:20:09 PM
By default, the applet comes with no furniture.
You should create a sh3f file for your furniture with the Furniture Library Editor, upload it on your web server, and give its URL in the furnitureCatalogURLs parameter.
