Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem Starting Online Version |
| Print at Aug 22, 2026, 7:17:04 PM |
| Posted by AnonDMV at Mar 8, 2013, 6:16:25 PM |
Problem Starting Online Version When trying to start the online version, I get the following error: ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet. Don't see this in the FAQ or another thread. Runing IE9 with Java 10.7.2. Thanks for any help. |
| Posted by Puybaret at Mar 9, 2013, 4:12:12 PM |
Re: Problem Starting Online Version Do you get this error when you try to run the Online version at this page, or when you try to run your own version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AnonDMV at Mar 14, 2013, 5:07:39 PM |
Re: Problem Starting Online Version I get the error when trying to run the Online version at "this page" (http://www.sweethome3d.com/SweetHome3DOnline.jsp). I have not attempted to install or use a download version. Thanks. |
| Posted by StNff at Mar 16, 2013, 1:55:59 PM |
Re: Problem Starting Online Version I Do get this error when I try to run my own version. And another question. In what directory should I have catalogs of furniture and textures? |
| Posted by StNff at Mar 17, 2013, 6:51:05 PM |
Re: Problem Starting Online Version P.S. ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DViever |
| Posted by Puybaret at Mar 18, 2013, 8:58:38 AM |
Re: Problem Starting Online Version StNff, I don't understand why you report an issue with com.eteks.sweethome3d.applet.SweetHome3DViewer in a subject about the Online version (i.e. com.eteks.sweethome3d.applet.SweetHome3DApplet class). What are you trying to do? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by StNff at Mar 18, 2013, 1:58:25 PM |
<font><font class="">
Re: Проблема Начиная Электронная версия
</font></font> I have compiled applet (ANT utility). I have this error when trying to start SweetHome3DApplet.html. http://osnova-mebel.com/3d/SweetHome3DApplet.html |
| Posted by StNff at Mar 18, 2013, 4:49:55 PM |
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>P.S. I have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet. I think I had another error yesterday. |
| Posted by StNff at Mar 24, 2013, 12:50:59 PM |
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> I had JDK 7. Now I have JDK 5 (As in the instructions). Log compilation: D:\1>ant javaWebStart Buildfile: D:\1\build.xml build: [mkdir] Created dir: D:\1\build\classes [javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 2 source files to D:\1\build\classes [javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 193 source files to D:\1\build\classes [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 261 files to D:\1\build\classes [zip] Building zip: D:\1\build\SweetHome3D.jar [delete] Deleting directory D:\1\build\classes application: [zip] Building zip: D:\1\build\SweetHome3DStandalone.jar [move] Moving 1 file to D:\1\build furniture: [zip] Building zip: D:\1\build\Furniture.jar textures: [zip] Building zip: D:\1\build\Textures.jar help: [zip] Building zip: D:\1\build\Help.jar jogl-java3d: [zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar java3dLibraries: [mkdir] Created dir: D:\1\deploy\lib\windows\i386 [zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\windows\x64 [zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\i386 [zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\x64 [zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\macosx [zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar javaWebStart: [mkdir] Created dir: D:\1\build\JNLP-INF [copy] Copying 1 file to D:\1\build\JNLP-INF [zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar [zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar [copy] Copying 6 files to D:\1\deploy\lib [delete] Deleting directory D:\1\build [input] Enter Passphrase for keystore: 1111 [signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D [signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё эрщЄш єърчрээ√щ Їр щы) BUILD FAILED D:\1\build.xml:238: jarsigner returned: 1 Total time: 1 minute 40 seconds Tell me, what's the problem? |
| Posted by Puybaret at Mar 24, 2013, 2:39:58 PM |
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> Reading the README.TXT file coming with the source file would have given you the answer: Note that the last part of the Ant targets javaWebStart, applet and viewer requires a passphrase for keystore to sign the deployed jars. For security reasons, the required file keys.keytool isn't provided with this source code. You'll have first to generate this file and choose a passphrase, with the following command run in the directory where you uncompressed this archive: keytool -genkey -keystore keys.keytool -alias SweetHome3D ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 22, 2026, 7:17:04 PM |
