Print at Oct 6, 2026, 4:58:33 AM
Posted by mnadeem at Mar 7, 2013, 12:34:31 AM
applause   day or night image
Hi i like to know how can i add day or night image or pic in background in plan , can any one please give intructions how to do that , i have create a home project but unable to add day and night situations
Posted by mnadeem at Mar 7, 2013, 1:01:57 AM
Re: day or night image
i have also not found ?
3D View -> Modify -> Sky texture -> Import
Posted by mnadeem at Mar 9, 2013, 11:35:39 AM
love struck   text on walls
sh3d,,, how can i write some text on walls and move it to any position, Do i have too make a photo print and then add it , i need some advise , thanks in regards
Posted by hansmex at Mar 9, 2013, 1:55:18 PM
Re: text on walls
Make an image of your text.
Import the image as a texture...
... and apply it to a thin box.
Place the flat box on front of your wall (as if it were a painting).
Posted by mnadeem at Mar 11, 2013, 9:56:50 AM
applause   Re: text on walls
Hi thanks for the supper answer , but how can i make a image + png or jpg and with what software , is there guide
second i have try to import some textures but it is too difficult for me
Posted by hansmex at Mar 11, 2013, 10:12:16 AM
Re: text on walls
1 - Use a graphics program like the Gimp
or
2 - Use a text processor to write out your text, then make a screenshot, and crop the image with a program like Irfanview
Posted by mnadeem at Mar 11, 2013, 12:03:12 PM
tongue   Re: text on walls
thanks in regards , but my ? is that how can i write some text or add pic or paste on the wall in any side and also can rotate with it . need info or advise how to make it in 3d
Posted by mnadeem at Mar 17, 2013, 10:11:18 AM
HI thanks i have done as you says it works but my ? is i want to make a wall then on it want to write some text , then this wall can be used in SH§D and rotate any side or make it big or small like i do in others textures and furniture
Posted by mnadeem at Mar 17, 2013, 10:14:55 AM
Re: text on walls
sorry write text or paste on the wall in 3d effects
Posted by hansmex at Mar 17, 2013, 11:46:43 AM
Re: text on walls
Maybe this will help?
Posted by mnadeem at Apr 21, 2013, 3:27:19 AM
Re: text on walls
Hi lately very busy . i still can not write text on wall . or i think i am not giving more information what i am trying to say, so i have a wall create in sh3d then give some colors , some people hanged there image or pictures , but simply want to write on it .then want to copy as a new furniture then export to obj format , so then i can use it many time as i wish , i hope not asking too much
Posted by Puybaret at Apr 21, 2013, 2:25:37 PM
Re: text on walls
There's no direct way to write a text on the wall. As Hans partly suggested, a workaround is to create an image containing that text (eventually with a transparent background), import that image in the program as a texture, and apply that texture on a thin box.
Of course, if you have to do that many times, it will become tedious and Sweet Home 3D might not be the right solution for you.
Posted by mnadeem at Apr 21, 2013, 2:33:55 PM
Re: text on walls
So back again . ?: If i have a pic or jpg or any type format how can i add to my furniture or as a object 3d still not understanding how this program works , in furniture import wizard only you can chose between obj,dae 3ds,lws,zip. but no jpg file , is there any one tell me what should i do thanks in regards
Posted by mnadeem at Apr 21, 2013, 2:43:14 PM
Re: text on walls
Ok if so
then tell me how can i add frame made by any picture or photo as , or my photo taken by camera to hanged in living room or bedroom
Posted by mnadeem at Apr 21, 2013, 2:50:12 PM
Re: text on walls
HI there must be a way to add 2D models import like 3D models import
Posted by Puybaret at Apr 21, 2013, 3:00:38 PM
Re: text on walls
As said previously, import the image containing your text in the program as a texture, and apply that texture on a thin box (found in Miscellaneous category).
Posted by mnadeem at Apr 21, 2013, 4:05:03 PM
Re: text on walls
hi as you say ,import the image containing your text in the program as a texture, and apply that texture on a thin box,, how is there any pdf file to understand , i have import jpg file but not found any where , its vanished
