Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Rendering does not use 100% CPU |
| Print at Sep 20, 2026, 12:38:53 AM | View all posts in this thread on one page |
| Posted by robal at Mar 4, 2013, 5:28:13 PM |
Rendering does not use 100% CPU Hi, It may be an odd question (and maybe better suited to Sunflow's forum), but: Does anyone experience low CPU usage during rendering ? When I render, my CPU utilisation is at around 60% (javaw.exe process) I thought it should be almost 100%, since Sunflow creates a thread for each core. I've tested this on two machines: - Core I7 860 (4 cores, 8 threads) - Phenom II 950 (4 cores, 4 threads) I'm wondering whether it's something funny about my machines (or my SH3D scene). Anyone ? |
| Posted by Puybaret at Mar 12, 2013, 1:32:24 PM |
Re: Rendering does not use 100% CPU What Java version do you use? Could you try with the installer version and not the Java Web Start version, to see if it behaves the same? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by robal at Mar 13, 2013, 2:53:00 PM |
Re: Rendering does not use 100% CPU Hi Emmanuel, I've noticed it first with Beta 4.0 and JRE7, but before making this post I've downloaded standalone 3.7, and it happens there too. Cheers |
| Posted by Puybaret at Mar 13, 2013, 2:58:18 PM |
Re: Rendering does not use 100% CPU Would you have any tool that would prevent a program to use all the CPU power? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by robal at Jun 19, 2013, 12:42:33 PM |
Re: Rendering does not use 100% CPU Hi Emmanuel, I haven't used SH3D for some time recently. Now I've downloaded version 4.1 and voila ! The issue is gone. It now uses 100% of CPU to render on my machine and renders almost twice as fast. Cheers, |
Current timezone is GMT Sep 20, 2026, 12:38:53 AM |
