Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Import Furniture |
| Print at Oct 6, 2026, 5:59:25 AM | |
| Posted by jim1600 at Mar 1, 2013, 2:35:08 PM |
Import Furniture I'm new at this. I imported some furniture. Then I tried to import some additional items. Somehow I now have 2 of each item I imported. Is there a way to remove them ? |
| Posted by Puybaret at Mar 1, 2013, 4:26:43 PM |
Re: Import Furniture Your issue sounds like this one. What did you try to import? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jim1600 at Mar 1, 2013, 5:50:13 PM |
Re: Import Furniture Thanks, The imported furniture works fine in the model. My problem is that they show up twice in the furniture library. I'm trying to figure out to eliminate the duplicate from the library. |
| Posted by Brasileiro at Mar 1, 2013, 7:45:33 PM |
Re: Import Furniture right click the furniture in the library > remove |
| Posted by jim1600 at Mar 1, 2013, 8:56:56 PM |
Re: Import Furniture Thanks |
| Posted by jim1600 at Mar 1, 2013, 9:13:23 PM |
Re: Import Furniture That worked once. Now when I right click, the only options are Copy add to home and import furniture. |
| Posted by Puybaret at Mar 1, 2013, 10:59:19 PM |
Re: Import Furniture You can remove only furniture you imported, and you can recognize them easily because they are written in italic. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 5:59:25 AM |
