Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception |
| Print at Sep 19, 2026, 11:23:26 PM |
| Posted by chicosRV at Feb 21, 2013, 11:08:24 PM |
I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception |
| Posted by Puybaret at Feb 22, 2013, 12:11:56 AM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception How did you create the jar file? What exception did you get? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by chicosRV at Feb 22, 2013, 5:23:51 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception I export the proyect as a JAR file with all the files and resources, and put the name of the main class. The proyect is exported but when I try to execute it, it simple says Java Exception ![]() |
| Posted by Puybaret at Feb 22, 2013, 8:05:15 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception As the project needs some DLLs, it can't work the way you did. You should generate a Jar file with the JarExecutable target of the Ant file provided with the project. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by chicosRV at Feb 26, 2013, 7:46:01 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception sorry but could you write me a step by step of how i could do this, i have never done this before |
| Posted by Puybaret at Feb 26, 2013, 7:50:13 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Do you use Eclipse? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by chicosRV at Feb 26, 2013, 8:37:58 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception yes |
| Posted by Puybaret at Feb 26, 2013, 9:12:36 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception - Select build.xml - In its contextual menu, choose Run as > Ant Build... - Select the target named JarExecutable - Click Run - Once finished, you'll find the Jar executable file in the install subdirectory (refresh its content with F5 if necessary) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by chicosRV at Feb 26, 2013, 9:36:25 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception it give the next error Buildfile: D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build.xml build: [mkdir] Created dir: D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build\classes [javac] Compiling 2 source files to D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build\classes BUILD FAILED D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build.xml:43: Unable to find a javac compiler; com.sun.tools.javac.Main is not on the classpath. Perhaps JAVA_HOME does not point to the JDK. It is currently set to "C:\Program Files\Java\jre7" |
| Posted by Puybaret at Feb 26, 2013, 9:45:58 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Select a JDK instead of a JRE in the JRE tab of Ant configuration. Don't forget that Google could help you too.... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 11:23:26 PM |
