Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: roof has block at end of it |
| Print at Sep 20, 2026, 1:20:47 AM | View all posts in this thread on one page |
| Posted by xtal_01 at Feb 13, 2013, 8:18:17 AM |
roof has block at end of it Hello, I read the tutorial and was able to draw a building complete with a roof. I created the roof in a separate window and then brought it in as furniture. My problem is that at the end of the roof is a large gray square block. I had the same problem on my last project. When I put in a triangle window, a large square chunk was taken out of the wall. I am sure it has something to do with blocks coming in as a rectangle. How can I get rid of this block? I wanted to make a picture out of the model but the block goes right on top of the building. I can post the file if it helps. Thanks .... Mike |
| Posted by Puybaret at Feb 13, 2013, 9:19:25 AM |
Re: roof has block at end of it This sounds like you exported/reimported a design with walls which contained a ground part automatically generated. Please read this post for a solution. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 1:20:47 AM |
