Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Need some Help with Roof and Ceiling ??? |
| Print at Aug 21, 2026, 9:32:57 AM | View all posts in this thread on one page |
| Posted by jubcheng at Feb 11, 2013, 6:22:08 PM |
Need some Help with Roof and Ceiling ??? Hi. Just got the software and like it quiet a lot, but there are a few things I can't figure out on my own. For instance there is this ready to use roof (see image below) which is called "Red Slate Roof" and I would like to change the angle of it so that if both parts of the roof put together giving a 90 degrees angle for example or any other angle specified. Another thing I can't figure out is how to display a ceiling. I added a second level and did set the drawn rooms to display a ceiling in a certain color but nothing is showing up, I guess I'm missing something here. Any help would be very much appreciated. Thanks in advance. Cheng ![]() |
| Posted by Puybaret at Feb 12, 2013, 7:55:24 PM |
Re: Need some Help with Roof and Ceiling ??? If you change the height of roof parts, you should be able to reach the 90° angle you target. You can also import again the Red slate roof 3D model, and change its orientation degree by degree in the second step of the furniture import wizard. Ceilings can be seen only from below. You should create a room at the upper level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jubcheng at Feb 23, 2013, 5:03:31 PM |
Re: Need some Help with Roof and Ceiling ??? ....... thanks for your reply. Got it working now, both the roof and the ceiling. Thanks again ....... |
Current timezone is GMT Aug 21, 2026, 9:32:57 AM |
